Old 10-26-2012, 10:54 PM   #1
AC fan runs when furnace is on
Recently purchased a 2012 Sunseeker 2450 used. The AC fan runs when the furnace is on. Is that normal ? Also was trying to install a winterizing siphon antifreeze kit and theres not enough room next to the water pump for the fitting. Anyone have a solution to this ?
hankwilliamsjrjr is offline   Reply With Quote
Old 10-26-2012, 11:37 PM   #2
jtstromsburg's Avatar
First guess on AC us that the T-stat is set to fan on hi or low and not auto
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-27-2012, 05:47 AM   #3
That is correct. Push the on-off button on thermostat to "fan". Then use + or - to change display to "au" (auto) instead of hi or lo. Return to furnace and furnace fan will run as needed but a/c fan will not.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 10-27-2012, 11:06 AM   #4
X2
Old 10-27-2012, 01:38 PM   #5
VinceU's Avatar
Anywhere in the suction line enroute to the fresh water tank, that's accessible. Must valve off tank and open to AF to accomplish the task. Best way is 3 way valve. One twist accomplishes both. The AC fan operating is good for circ of the warm air, thats the reason for it.
Old 10-27-2012, 08:46 PM   #6
Had a similar problem on my 3120. Inlet to the pump was right at an elbow. Installed the three way valve with the pump suction to the leg of the 3 way valve "T" and the anti freeze hose connection at the bottom. Had to file off the valve stop so it now rotates 180 degrees instead of just 90 to swap from normal to antifreeze bypass. Just a little pipe fitting work to plumb it up, new straight fitting to replace the elbow and shortening of the flex hose to get things to line up. If you like I may be able to get a photo.
ATVer is offline   Reply With Quote
Old 11-11-2012, 03:07 PM   #7
I appreciate everyone's help on these issues. This forum is sure a wonderful help to beginners like me !!!
Old 11-14-2012, 10:07 PM   #8
Jean & Walt's Avatar
Originally Posted by Wiscampsin
X2
Does this work for the AC? We are new to RVing - AC fan runs constantly only the compressor turns on and off!
Jean & Walt is offline   Reply With Quote
Old 11-14-2012, 10:14 PM   #9
[QUOTE="123WHPJTP321"]
Does this work for the AC? We are new to RVing - AC fan runs constantly only the compressor turns off and on.
QUOTE]
Old 11-14-2012, 10:24 PM   #10
Yes.
Does this work for the AC? We are new to RVing - AC fan runs constantly only the compressor turns on and off![/QUOTE]
Joel and Teresa
2016 Sabre 34TBOK
fan
