Old 08-20-2014, 08:06 AM   #1
ac/heater thermo
we have a 2014 2860 how do we control the temp, we put the setting on cool say 70 but ac will run all the time, is there away that it works like in a home auto on/off ?
retired on a mountain is offline   Reply With Quote
Old 08-20-2014, 08:15 AM   #2
Is the compressor running all the time or just the fan? Check to make sure your fan is set to 'AUTO' ?
Old 08-20-2014, 09:25 AM   #3
What's the outdoor temps?
biznsa is offline   Reply With Quote
Old 08-20-2014, 09:56 AM   #4
yes compresser is running temps at night 60s days 80s if i lower set point to 60 let it run for a hr then change temp setting to auto 70 it schould turn off but it doesn't seems to blow warmer air out ac ducts the unit does blow cold air, might need to get temp gauge put next to thermostat to check temps
Old 08-20-2014, 09:59 AM   #5
TURBS's Avatar
Sounds like fan is set to on instead of auto.
TURBS
"SABRE OWNERS UNITED"
Old 08-20-2014, 02:24 PM   #6
If the fan is set to auto, then yes it should cut off after a delay of maybe 30 seconds. If the fan is set to on the compressor cuts off but the fan keeps running. Personally I like the fan on all the time as it seems less intrusive to me (esp at night) than cutting on and off. But, that point aside, if you are sure the fan is on auto and sure that the compressor keeps running then I would think bad thermostat. It could be something else but I like to start with the cheap and easy fixes first.
jrwalkerpa1 is offline   Reply With Quote
Old 08-20-2014, 06:43 PM   #7
tmhyer's Avatar
Having it set to 70 is pretty low. Try raising it
tmhyer is offline   Reply With Quote
Old 08-22-2014, 09:12 AM   #8
ok thanks ill try this weekend
Old 08-31-2014, 08:34 AM   #9
Ok seems to be ok now I might of bad setting set to auto fan thanks
heater
