Old 09-02-2019, 05:36 PM   #1
ac leaking inside
Read several times about the ac leaking inside MH. Here is my story from camping this weekend. Leaking water from ac, called dealer and finally got the lead tech and this is what he said, remove the cover on the inside of the MH and look and see if the divider had moved and if it has (what divider I said). Explained that the ac was into two sections, return and cold air and if the divider is loose or not in the right place, the return air (warm air) will mix with the cold air and condensation will happen. That is what was wrong with my MH. Now how to fix, use that silver tape, (used on vents in home ac) and tape all four sides with it, or bring it here (appointment is in Nov) I will get tape and fix it my self. Once the divider was correct (?) no more leaking and easy fix instead of crawling on roof which would not have fixed it.
SQROOT is offline   Reply With Quote
Old 09-03-2019, 03:48 PM   #2
Usually Confused Member
emm-dee's Avatar
Call Dometic. Ask for Service bulletin 3315930.010. It’s free and takes <15 minutes to install.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
leak
