Old 06-23-2016, 06:49 PM   #1
Frankie Z's Avatar
AC won't shut off automatically
My AC keeps running no matter how high I set thermostat it will only manually shut off. I would appreciate any suggestions on what could be causing this.
Frankie Z is offline   Reply With Quote
Old 06-23-2016, 06:53 PM   #2
Georgia Frog Rally 2017
aceinspp's Avatar
Is it set to auto or manual? Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 15
Days booked so far in 2017 37
Old 06-23-2016, 07:31 PM   #3
You may have it set to continually run the fan part of your A/C. The compressor cycles but the fan never shuts off. As mentioned, check the thermostat's fan setting.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 06-23-2016, 07:37 PM   #4
Frankie Z's Avatar
I will have to check the week of the 4th when I go out again. I hadn't thought of the fan just running I was assuming the AC was running also I'm not sure. I will have to pay closer attention but I know I had ac on automatic not manual.
Old 06-23-2016, 09:59 PM   #5
MH Noob
I ran into the same thing when I first got mine - somehow managed to take it off of Auto when messing around with the thermostat.....
Slimjc is offline   Reply With Quote
Old 06-24-2016, 10:59 AM   #6
Chief tinkerer
Gidyupgo's Avatar
Frankie, you may already know this but I didn't. I discovered on ours, as you cycle through Heat, AC, Fan, Furnace, on the thermostat you stop on Fan and use the up down buttons to change from fan auto, high, low.
Gary
2017 SunSeeker 3010DS
Gidyupgo is online now   Reply With Quote
Old 06-25-2016, 07:10 AM   #7
Wolverine 1945's Avatar
There is always the chance that you have a bad thermostat,,,
Maybe it got damaged on its trip here from China ???
Wolverine 1945 is offline   Reply With Quote
Old 06-25-2016, 05:15 PM   #8
Frankie Z's Avatar
I didn't even know the fan had different speeds
Old 06-26-2016, 05:54 AM   #9
I don't think it does ???
Old 06-26-2016, 09:35 PM   #10
I don't know if all of the units have multi speed fans but mine does...the 15k unit with heat pump. The fan can be set to high, low or auto. If set to high or low the fan runs all the time. If set to auto it kicks on and off with the compressor. It is easy to hear the difference in the sound when the compressor is running versus just the fan. Depending on the situation, I use it both ways. For instance at night, the sound of the fan running constantly is less likely to wake me up then for the unit to turn on and off each time the compressor cycles.
jrwalkerpa1 is offline   Reply With Quote
