Old 01-14-2016, 12:17 PM   #31
wmtire's Avatar
Originally Posted by MOODMAN View Post
One thing I would like to have seen in that diagram from DAVEL1971 is where the wire is connected on the backside of the receptacles. In other words, which holes in the plug go to which wires!
It's on the pdf file in post #2 from Flybob.
That pdf and much more comes from here:
http://www.myrv.us/electric/index.htm
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-14-2016, 12:55 PM   #32
KAS
Originally Posted by budblack View Post
Be sure that the electrician knows it is for 30 amp RV service, not household service. The receptacles are different.
Unless you want to use the outlet for other purposes also, in which case you can use an adapter on the RV power cord plug to make it fit a regular 30A outlet. That's what I did and it works great.
KAS is offline   Reply With Quote
Old 01-14-2016, 01:07 PM   #33
Flybob's Avatar
If you are saying you put a standard 3 prong 120V 20A household outlet on a 30A circuit, you could have a problem. Most electrical prohibit this.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-14-2016, 01:15 PM   #34
I ordered a Connecticut RV box from Home Depot. It has 50/30/15 amp plug ins. Had an electrician run the lines. No problems.
Rick_Geneseo is offline   Reply With Quote
Old 01-14-2016, 01:18 PM   #35
KAS
My MH came with adapter for the power cord. Why would they include it unless it is legal? I have also used a SHORT 10-gauge extension cord with a regular plug in the past with no problems (as long as it's 30A).
Old 01-14-2016, 01:31 PM   #36
Kenny kustom's Avatar
He is correct.
30 amp breaker feeding a 20 amp outlet. ( bad idea)
The adapter is the other way.
20 amp house feeding a 30/50 amp coach.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-14-2016, 01:33 PM   #37
KAS
Originally Posted by Kenny kustom View Post
He is correct.
2016 Sabre 36QBOK
The outlet is 30A, installed by an electrician.
Old 01-14-2016, 01:38 PM   #38
Add both a 30 and 50 amp for the future.
rwatson908 is offline   Reply With Quote
Old 01-14-2016, 01:38 PM   #39
Perfect!
2016 Sabre 36QBOK
Old 01-14-2016, 01:49 PM   #40
RV plug
Other contributors are right in that it's 30amps of 110 and not 220 but you might ask him how much more to run a 50amp 110 wire so if you upgrade in the future you just need to change the breaker and the outlet.
DocRob is offline   Reply With Quote
