Old 01-13-2016, 07:54 PM   #1
Adding RV Plug At House
We are considering adding an RV plug at the house (along with some other work). An electrician is coming tomorrow morning to do an estimate. I know nothing about electric. What do I need to tell the electrician for the RV plug? I know 30 amps (and I have a picture of the prongs so he knows which plug). Is there anything else such as volts to tell him?
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 01-13-2016, 07:58 PM   #2
Flybob's Avatar
Make sure you tell him it is 30A 120V service not 220V. See attached.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-13-2016, 08:10 PM   #3
davel1971's Avatar
here's another look at it. Shows both 30 and 50 amp in this one.
David & Lynn
Old 01-13-2016, 08:33 PM   #4
wmtire's Avatar
Just print out the pdf file to hand to your electrician that Flybob posted above, and you should be good to go.
He just needs to make sure he understands that it's 120 volt ONLY.
We also keep a copy of that pdf in the FAQ section (link below), just so everyone knows for future reference:
http://www.forestriverforums.com/for...let-27223.html
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 01-13-2016, 08:38 PM   #5
Mr. Dan's Avatar
I suggest you consider the day when you might want to move to a 50A trailer - pull enough wire of the right gauge to support 50A so you don't have to get into the wall if you change trailers.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 01-13-2016, 08:55 PM   #6
Citrus County, Fl.
GL1800Rider's Avatar
I ran my 50 amp TT off the 30 amp that has #10 wire along with a dog bone. As long as you only turn on one AC it's fine. But, you may want to get an estimate for each type and decide what you want to do
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 01-13-2016, 09:07 PM   #7
Brother Les's Avatar
imo.....put in the 50 amp and you can dog bone that down to a 30amp.
Brother Les
Old 01-13-2016, 09:11 PM   #8
TURBS's Avatar
I agree!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-13-2016, 09:13 PM   #9
If you want just 30 amp ask for a TT 30R receptacle. Everyone here is offering good advise. I'm with GL1800rider 30 amp service is OK majority of time at home. I'm not an electrician but most homes have just 200 amp service. Putting in a 50 amp receptacle will consume 100 amps of the 200 available(not that you would actually use all 100 amps but you could). Most honest electricians will advise against it. Plus it will be cheaper to install.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 01-13-2016, 09:21 PM   #10
200 amp service on the typical home is 200 amps per 120v leg. Likewise 50 amp service is 50 amps per 120 v leg, not 100 amps as you state.
WY Husker Fan is offline   Reply With Quote
