09-03-2015, 11:39 AM
Agm battery
Is it worth going from lead acid wet battery to a agm type battery?
John and Diana Embrey Texas 2019 Coachmen Mirada 35 KB
09-03-2015, 11:44 AM
I sure hope so as I just did. Nautilus group 31 ultra AGM
09-03-2015, 02:11 PM
I've had both.....I just bought two Group 31 AGM from Sam's Club for $179 each....Couldn't pass it up.
Problem has always been cost. Usually at least twice as much as a wet cell.
I love the idea of not having to maintain an AGM. I have one on a back-up sump pump here in the house that is going on 8 years and it is still in perfect shape. Using an Optimate charger to keep it charged. Only chargers I've ever owned that won't damage a battery. I have a couple motorcycles with ten year old batteries always on an Optimate and they are still fine.
09-04-2015, 06:13 AM
x2 on Sam's Club AGM. Old battery (original) was failing and gasses were setting off CO/LP detector. Much better to have sealed batteries with no maintenance issues. 2012s only came with one battery, so took the opportunity to upgrade to two. As others have said, two battery setups must have matching batteries.
2012 Forest River Sunseeker 2300 Chevy
09-04-2015, 06:22 AM
Converted to AGM
I switched to AGM battery, series 31 from SAM's Club two years ago. Will not go back to wet cell battery. Got larger battery box from PPLmotor homes.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2022 51 DAYS
[SIGPIC][/SI[SIGPIC]
09-04-2015, 09:27 AM
I have 3 AGM batteries in my 5er and one on our ATV. Love them no maintenance and no acid vapors.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
09-04-2015, 09:41 AM
Location: Alberta - East of the Rockies, West of the Rest
I love them, this our 2nd 5er with AGM's.
Are they worth the price - no.
Almost zero maintenance and no corrosion - priceless.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
09-05-2015, 04:40 PM
Two group 31 AGM in mine and changed to a better converter than what came with RV.
09-08-2015, 08:38 PM
What batteries did you get from SAMs? Duracell?
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
09-08-2015, 08:50 PM
Just bought three AGM 31 batteries from Interstate. A ton of amp hrs, but big time expensive. Also, they have a three year unconditional replacement warranty. I'm not sure any other battery manufacturer offers that. I actually bought them for their amp hr ratings. $265 each!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
09-08-2015, 09:11 PM
So what is there amp hr rating?
09-08-2015, 09:31 PM
190 amp hrs each according to the figures the rep went over with me and how they figured it with reserve rating. My other batteries were 125 amp hrs, but were flooded and I didn't want them in an enclosed area even though the area is power vented.
They just do fit into a 31 battery box with no room to spare, but are taller than the other batteries and weigh about 4 lbs more [71 lbs].
09-23-2015, 09:04 PM
Below is the Interstate site for the Group 31-AMG7 batteries. Scroll down to see the specks.
Interstate Batteries Results Page - D replacement battery
09-24-2015, 06:35 AM
I`ve had an AGM in my Excursion since 09. it still turns over quick, has never gone dead, and the biggest thing.....no corrosion on the terminals!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
09-28-2015, 08:49 PM
If your batteries are outside the RV and not in an enclosed area, flooded batteries are OK. If your battery compartment is in an enclosed compartment, AMG is the only way to go. No gases or maintenance on the AMGs.
It just depends on your bats location AND how much you want to spend. AMGs are pricey, but you get what you pay for and AMGs charge much faster than lead/acid bats.
09-29-2015, 12:26 AM
Yes, SAMs batteries are Dracell
09-29-2015, 01:39 AM
190 amp hrs each according to the figures the rep went over with me and how they figured it with reserve rating. My other batteries were 125 amp hrs, but were flooded . . . .
Mike,
The spec sheet you pointed to says:
ReserveCapacity-25: 190.00
What that means is that when the battery is supplying a constant 25 amps, it will be able to keep that up for 190 minutes. That is not an amp-hour spec. This spec sheet does not give an amp-hour spec. That is suspicious. It is probably not a true deep cycle battery. Notice how they emphasize Cold Cranking Amps. This usually means that it was really designed primarily as a starting battery.
Amp-hours for a typical Group 31 deep cycle battery will be in the neighborhood of 105 Ah when measured using a 20 hour discharge rate. It is common to spec and compare amp-hours using a 20 hour discharge rate for deep cycle batteries. You might see amp-hours listed using other discharge rates, but look first to see what the battery amp-hour rating is using a 20-hour discharge rate.
Take for example, this Group 31 AGM battery:
Duracell® AGM Deep Cycle Marine and RV Battery - Group Size 31 - Sam's Club
These specs give amp-hours for various discharge rates, but at the 20 hour rate, it is spec'd at 105 amp-hours. You might also notice that its Reserve Capacity at 25 amps is 210 minutes.
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
09-29-2015, 04:28 PM
Dang it
Everytime I read sump'en that's got Rvbill attached to it I seem to spend money. So what two AGM batts fit in the 2300 footwell?
I tell DW I am just doing the required mechanical upgrades as called for on "the forum". There will be a day when that dog won't hunt....
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
09-29-2015, 06:08 PM
I am using two group 31 Blue tops in my SunSeeker 3100SS. Changed out the controller to a staged one with 305 watts of solar on the roof. More than enough trouble free power! Have an Optima in my Hot Rod that's been working since 2000.
09-29-2015, 06:21 PM
Just for reference. Normal automotive service is different than camper and misc. service. Open the hood of your car or TV. Whew it's hot. They even put blankets on the batteries now a days.
The real secret to battery life is maintenance...especially on ones that set months at a time....yes I sold batteries for 25 years.
2017 Puma 297RLSS
