Old 05-17-2014, 03:12 PM   #11
I'M going to see a repair shop in a couple weeks to get it
fixed.
Phelpo
phelpo is offline   Reply With Quote
Old 05-17-2014, 05:20 PM   #12
tmhyer's Avatar
The valve on one of mine leaks after I check the pressure. I have to press the guage on it a few times for it to stop.
Sent from my SCH-I545 using Forest River Forums mobile app
tmhyer is offline   Reply With Quote
Old 05-17-2014, 05:43 PM   #13
Ford Idaho's Avatar
Originally Posted by phelpo View Post
One bag stayed at 60lbs the other went done to 20 lbs
I checked the values and no air bubbles
Plastic air lines?
Spray them down with soapy water look for pin holes.
Old 05-17-2014, 06:55 PM   #14
Good idea if you could get to it. Covered with plastic covering And foam insulation
Old 06-11-2014, 07:28 PM   #15
update, was referred to campers inn in Jacksonville fl, they ended up replacing both air lines since they could not find the air leaks, got my fingers crossed and prayers lifted up
Phelpo
Old 06-16-2014, 08:11 AM   #16
they held the air, great....
Phelpo
Old 06-20-2014, 08:15 AM   #17
I would suspect the schrader valve before anything else. I've soaped the valve before and often get a slight bubbling. The caps aren't going to hold 80 psi back.
On the tubing, Firestone manual points out in the install of the tubing to make the cut as square as possible and insert the tubing as far as possible into the fittings.
bgilly is offline   Reply With Quote
