Air bags are part of the suspension designed to assist in getting a stable, comfortable ride. They "dampen" the movement of the springs. They do help keep the MH "level", in that they assist the other suspension parts depending on the load. (Actually, "level" is not what you want. A slight nose-down position will ride better.) The air bags can also be adjusted to a firmer ride (more air) when in a cross wind to help avoid rocking back and forth. They are not really for leveling a parked MH, but some people do add pressure to them when parked to stabilize the MH a little.
Tires pressures should be adjusted according to what is says on the sticker on the driver's door frame. For my Chevy chassis, it is 65psi front and 80psi rear. Yours may be different.
Ford chassis seems to need a front end alignment--use specs found elsewhere on this forum.
Some have added stabilizers and different shocks, but don't even consider until you check tire pressures, alignment, and try different pressures in the air bags (anything between 5 and 100--try 50 to 60 to start). Also make sure you are not overloading the MH. If there is any question about that, take a trip to the scales and get weighed.
2012 Forest River Sunseeker 2300 Chevy
