Old 04-24-2015, 09:07 PM   #1
2015 Sunseeker 2300
air bags
Need help with the air bags on our Sunseeker 2300. It is a new 2015 and we have not touched the air bags. The service tech said he inflated 1/2 way when we picked up the unit. Now that it is fully loaded and we are carrying a scooter (200 lbs) on a carrier in the trailer hitch do we need to increase or decrease the air in the air bags we will be traveling about 200 miles mostly on interstate and what is 1/2 way how do you know how much to keep them inflated to? Thanks for all advice we are new to this..
Gingsnap is offline   Reply With Quote
Old 04-24-2015, 10:20 PM   #2
He you have the Big Foot Jacks I would so you have plenty of clearance, We have a 2014 3010DS and we always keep them at 75psi when traveling.
goots is offline   Reply With Quote
Old 04-25-2015, 04:42 PM   #3
I have a 2014 3010 and usually keep mine at 60 psi. We also tow a Chevy Equinox and the ride seems to be ok with that. There probably isn't a wrong psi unless it's at zero or over 100.
Bednarski1 is offline   Reply With Quote
Old 04-25-2015, 05:01 PM   #4
Since you are new to this keep in mind, if you ever have to lift wheels off the ground (as in jacking it up) you must deflate air bags to zero. Then re inflate when wheels back on ground.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-25-2015, 05:15 PM   #5
I talked to the tech at Firestone who makes the Air bags and he said no need to deflate air bags
Old 04-25-2015, 05:21 PM   #6
OK - not what it says in manual though. Did he say lifting by frame or by axle?
2014 Forester 3051s
2012 Sonic toad
Old 04-25-2015, 05:44 PM   #7
Average Joe
MrJoe's Avatar
I've never deflated mine when using the levelers. About a year and a half with no ill effects. I do not add air while jacked up. I can see how that would cause damage. I will be sure to post if damage is ever caused by not deflating when using the jacks.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 04-25-2015, 05:49 PM   #8
Mr Joe , I am talking about lifting BOTH rear wheels off the ground, as in jacking up to work on rear axle. I may have not been too clear in original post.
2014 Forester 3051s
2012 Sonic toad
Old 04-25-2015, 05:58 PM   #9
Average Joe
MrJoe's Avatar
I can say I don't intentionally lift the rear wheels. When I see the wheels may lose contact with the ground, I use pads and blocks to keep contact. Guess that's why I've never had airbag problems.
Joe and Karen
Old 04-25-2015, 07:34 PM   #10
Air bags can be filled anywhere from 5 to 100psi. The only way to determine "half way" would be to check air pressure. How much air to use is totally up to you. The goal is to keep the right attitude of the MH (front end slightly down from rear end). More air will give a stiffer ride which can be very helpful in dealing with crosswinds. I would start at 60-65 psi and see how you like it. With a heavy load on the rear, you might add a little more. Just make sure when adding air that you use very short bursts. It takes very little air to fill the bag.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 04-25-2015, 07:48 PM   #11
Ford Idaho's Avatar
If you are lifting to work on the rear axle then Jack it under the axle.
If you try to lift the axle off the ground using the frame then you could damage the suspension components.
Old 04-25-2015, 08:09 PM   #12
Another thing to keep in mind is you have to check the air often. They do lose air over time and sometimes faster than you expect. I air mine up about once a week. I just recently installed an onboard compressor for the airbags with the control switch and gauge in the cab. . A pain in the neck (and lower) job to install but worth it.
jrwalkerpa1 is offline   Reply With Quote
Old 04-25-2015, 08:33 PM   #13
Thanks for the recommendation. Do you use air compressor or bicycle pump?
SkipnTerri is offline   Reply With Quote
Old 04-26-2015, 05:11 AM   #14
I use a small tire inflator (like for bicycles) for the air bags just because I am afraid of filling them too fast with my air compressor. If you are careful and use short bursts, I'm sure either would be fine.
Old 04-26-2015, 10:40 AM   #15
I picked the Goodyear brand air compressor at Walmart on-line and it works great I keep it stored on the RV it small enough to do the work...
Old 04-26-2015, 03:52 PM   #16
Hey Ford,you know we are talking about motorhome not trailer. thats why manual states to dump air from air bags before lifting from frame.
2014 Forester 3051s
2012 Sonic toad
Old 04-26-2015, 04:16 PM   #17
Ford Idaho's Avatar
Hey if you want to lift a MH rear axle off the ground using the frame go for it.
I have a question, if something gets broken when you do that, who pays?
Old 04-26-2015, 04:27 PM   #18
Where do you think the auto levers are attached, the frame, and a lot of people lift their wheels off ground using them, I don't !!!All I was stating is that the manual states to dump air from air bags if lifting from frame. I have a question for you, when you take your car/truck into repair shop and they lift it using a frame contact hoist what is the difference?
2014 Forester 3051s
2012 Sonic toad
Old 04-26-2015, 04:40 PM   #19
Ford Idaho's Avatar
When the tire are rotated at Discount tires they use floor jacks under the axles.
The rest of the truck gets serviced over a pit so the tires never leave the ground.
On top of that my Ford DOES NOT have air suspension on it.
Good luck with the air suspension....
Old 04-26-2015, 04:54 PM   #20
When the tire are rotated at Discount tires they use floor jacks under the axles.:
Maybe at the particular Discount tire you use, but, there are more than one Discount tire that use frame lifts. Not too many pits left in modern shops.
air bags
