Old 03-19-2019, 06:52 PM   #1
air bags fixed
Told the dealer that there was something wrong with the air bags on my 3010 sunseeker. Bring it in. I did today and it was fixed, Too many washers on the fitting and debris in the air connector. 100Lbs and does not drag in driveway. Whoopee. Still learning this rig through.
SQROOT is offline   Reply With Quote
Old 03-19-2019, 09:57 PM   #2
Usually Confused Member
emm-dee's Avatar
If it's like all the other Forester/Sunseeker units with air bags it will leak down and needs constant attention. I added an AirLift Wireless One remote compressor and it works great. It's and easy install.
Don't expect a lot of rear height change...from 5 psi to 100 psi my unit only goes up about 2.5 inches.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 03-19-2019, 10:30 PM   #3
Up 4 inches
Old 03-22-2019, 03:55 PM   #4
I can't even get air into mine (valves in the compartments, both sides won't take air), maybe it's just debris in the airline or the valves are stuck.
2013 Sunseeker 2650
2015 Jeep Wrangler
stevemoores is offline   Reply With Quote
Old 03-22-2019, 04:17 PM   #5
take them apart and clean, but the valve were not protruding out far enough to get a good connection. had to remove some washers.
Old 03-22-2019, 04:41 PM   #6
RETIRED
n-e-d's Avatar
Found a kink in the line on the passenger side airbag where FR installers tied up all the extra line. Lots of line so it was easy to cut out the kink. Also adjusted the valves in the compartment. I also went with a onboard compressor system with gauges in stairwell. Makes life so much easier
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Rover"
n-e-d is offline   Reply With Quote
Old 03-22-2019, 10:45 PM   #7
N.E.D
What kind of onboard compressor system?
Old 03-22-2019, 11:01 PM   #8
emm-dee's Avatar
Originally Posted by SQROOT View Post
N.E.D
I used the AirLift Wireless One. Very easy install.
Old 03-23-2019, 04:41 AM   #9
RETIRED
n-e-d's Avatar
N.E.D
I have the Airlift analog system. Its a little more work to install but I like the gauges and fill/release buttons in the stairwell
Just an additional thought after adding the Airlift I noticed I wasnt losing as much pressure in the bags in use
Mary and Me
2015 Jeep Cherokee
air bags
