Old 07-20-2013, 02:03 PM   #1
Sunseeker 2500TS owner
Air Cond drain on 2500TS
Water from roof air conditioner drips down drivers side along drivers door and side of the Sunseeker 2500TS. The 2500TS does not have a ladder so it is hard to get up there and look. Should there be a drain or dripping down around drivers door is normal? 2500 was level both ways.
Thanks.
ejkkj is offline   Reply With Quote
Old 07-20-2013, 02:39 PM   #2
Garrette's Avatar
Mind drips down the passenger door or onto the awning. I guess it depends on the level.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 07-20-2013, 03:16 PM   #3
MotocrossCamper's Avatar
Yes its normal. It has to drip somewhere no matter how level you are. Eventually enough water is going to build up on your roof that it has to run off. It should be draining from the end of your gutters.
My shower drain is toward the passenger rear side of the camper so I always leave the right rear corner the low spot when I level. That way the AC water drains to the rear of the camper and my shower drains properly.
MotocrossCamper is offline   Reply With Quote
Old 07-20-2013, 04:22 PM   #4
Gutter Extensions ??
I have always installed gutter extensions on my RV's. Really don't want it dripping down the windows or outside walls.
RV Gutter Extensions, 4-pack - Camco RV 42123 - Awning Accessories & Hardware - Camping World
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 07-20-2013, 04:35 PM   #5
Made mine out of 3/4" pvc about 3" long and put a pop rivet in the bottom to hold them on.
Name:	Rear view of extra extension for gutter extension.jpg
ID:	35828   Click image for larger version
Name:	Extra extension for gutter extension.jpg
Old 07-20-2013, 05:20 PM   #6
Chris1304's Avatar
I personally don't like the water dripping from the gutters right outside the door of my camper! An easy fix on this is to tie a string from the end of the gutter to a tent stake on the ground well away from the camper and out if the way .. The water runs right down the string with no drips !
Chris1304 is offline   Reply With Quote
Old 07-20-2013, 06:48 PM   #7
Denver, CO
garbonz's Avatar
mine skips the gutters and runs down the back of the camper down the window and on the ground. My fiver has a pronounced slops toward the rear. Nuting I can do about it.
2017 Fuse 23T
Old 07-20-2013, 07:14 PM   #8
You can always take a strip of Eternabond and fabricate a ridge and route it anywhere you want, like toward the gutter.
Old 07-21-2013, 07:09 PM   #9
RV Nomad
I just got a 2500ts myself about 6 weeks ago. It doesn't seem to matter if I'm perfectly level or not, my AC drains from my front gutter extensions(the ones that came from the factory) and down onto my side mirror arms. It does not run down the side of the coach or doors of the cab.
xgzx is offline   Reply With Quote
Old 07-21-2013, 07:17 PM   #10
On my #3051S they drip on the side view mirrors with gutter extensions installed. But swinging both mirrors in was simple.
Tim
