Old 10-02-2013, 06:08 PM   #1
2013 SunSeeker
Air Condition/Generator Problem
We have a new (2013) 3117 Sun Seeker purchased earlier this year. We were getting ready to go on weekend trip (after not using a couple of months), checked out generator, a/c, etc. The a/c would not come on using generator but would work using house power. Any ideas?
thanks,
George & Janet White
and 2 4-legged friends
2013 Sun Seeker
GeorgeHW is offline   Reply With Quote
Old 10-02-2013, 06:16 PM   #2
Ford Idaho's Avatar
Did you check the generators circuit breaker?
Old 10-02-2013, 06:52 PM   #3
Herk7769's Avatar
Check your water heater AC switch. If it is on, you will exceed the amperage (start up) and the generator will not stay on line.
HAM CALLSIGN - KC3FFW
Old 10-03-2013, 03:04 PM   #4
30amp breaker?
Sounds like the 30amp breaker on your generator is off or tripped off. Does the generator power any 110 volt outlets when on?
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 10-03-2013, 04:28 PM   #5
2013 SunSeeker
Thanks everyone for the speedy replies. Hopefully this hurricane/storm will hold off a few days and I can check these out. I will let everyone know the outcome.
2013 Sun Seeker
Old 10-04-2013, 05:24 PM   #6
2013 SunSeeker
Resolved AC issue
Thank you again to everyone that replied. Tim, you were correct it was the generator 30amp breaker was in the off position. Once I flipped it to on, started the generator, turned the a/c on - IT WORKED! So especially THANK YOU to you!
Hope everyone has a safe weekend and hopefully we will run across each other at one of these campgrounds in the future.
2013 Sun Seeker
Old 10-04-2013, 06:18 PM   #7
I use a plug-in style voltage monitor for my 110 volt power. It has an LED display that shows your volts and polarity. This is one of the first things I check if power goes out inside the RV.
Tim
generator
