Viberation in AC
Had bad vibration in my AC. While at the rally, Tech Team removed A/C & replaced the gasket (dough-nut gasket) between the AC and roof with thicker gasket. Vibration gone. I had stopped the vibration by raising the AC slightly, inserted a sponge door mat under the AC, vibes stopped!!!!! It worked until the rally which then the permanent fix was done by Techs.
Try running AC, get on roof, lift the rear of AC slightly to see if the vibration stops. If it does, replace gasket between the AC and roof. There is a thicker gasket available for AC. Or purchase a kitchen or door sponge
mat from Lowe's. Cut about 6" off mat, insert between the bottom of AC
and roof.
Good Lucho
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
