Old 07-30-2014, 03:16 PM   #21
Witch Doctor's Avatar
Had the same problem they replaced the motor, blower wheel and the condenser fan blade, Make sure they replace the motor to, because it has damaged the shaft for sure. Which is a double shafted motor.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-11-2014, 04:41 PM   #22
Finally took it to a dealer to check out...they're recommending that I replace the entire a/c unit. Said that replacing parts inside these units gets costly and may or may not fix my issue. They want close to $1,000 plus tax. Seems to me with a proper diagnosis of the issue they should be able to narrow it to a faulty part (or system) and replace what's needed...maybe I'm missing aomething. For those who had fans and motors replaced...what did that cost? I asked my dealer to get me a price for just a new motor...they're calling me back tomorrow.
rad_jr is offline   Reply With Quote
Old 08-11-2014, 06:38 PM   #23
Oklahoma Proud
MillerTime's Avatar
My neighbors just had a broken fan (1 blade was broken) replaced at thier site. It was about $10, plus a $50 service call fee. I think they might have had it cleaned and filter changed, and I don't know how much that part cost.
I try somebody else before scrapping it for a new one. Just my thought though.
Old 08-12-2014, 12:09 PM   #24
Now we're down to just replacing the fan and motor... $440 plus tax and "that's not guaranteed to fix the problem". How big a job is it to replace the fan and motor?
Old 08-12-2014, 01:49 PM   #25
If you just replace the motor you might still have a problem real soon again. The motors are doubled shafted so either the condenser fan blade and the blower wheel could be also out of balance. That will happen again if you do not replace both at the same time. The new motors have different mounting holes they have to line it up perfect or you will still have a problem. Mine cost $535.00 labor and all parts. Good luck
Old 08-12-2014, 03:45 PM   #26
parpar1's Avatar
I think i am going to demand they replace the whole unit and fight them piece milling it.
parpar1 is offline   Reply With Quote
Old 08-12-2014, 04:07 PM   #27
The dealership wants to replace the whole unit...I'm out of warranty so it will be at my expense. I'm trying to decide if it's worth paying to replace the whole thing when the problem is likely caused by a single component. Just spoke with them again...they've contacted the a/c manufacturer to see if they'll help out. We'll see what happens....
Old 08-13-2014, 06:11 AM   #28
DAISY BOYKIN's Avatar
Viberation in AC
Had bad vibration in my AC. While at the rally, Tech Team removed A/C & replaced the gasket (dough-nut gasket) between the AC and roof with thicker gasket. Vibration gone. I had stopped the vibration by raising the AC slightly, inserted a sponge door mat under the AC, vibes stopped!!!!! It worked until the rally which then the permanent fix was done by Techs.
Try running AC, get on roof, lift the rear of AC slightly to see if the vibration stops. If it does, replace gasket between the AC and roof. There is a thicker gasket available for AC. Or purchase a kitchen or door sponge
mat from Lowe's. Cut about 6" off mat, insert between the bottom of AC
and roof.
Good Lucho
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
air conditioner
