Old 05-29-2013, 08:23 PM   #1
Cool Air-Lift valve stem length
I was checking the PSI in the air-lifts and discovered the passenger side stem would not accept the air gauge. It was not out far enough.
Guess I will have to loosen, reposition, and tighten. Makes you wonder how they inflated to 65PSI..unless they come from the factory pre-set.
Wildkats66 is offline   Reply With Quote
Old 05-30-2013, 08:19 AM   #2
Sunseeker 2500TS owner
Mine was same in new 2500TS, I used valve extenders. Or as a quick fix take one off a tire to use for checking pressure.
ejkkj is offline   Reply With Quote
