Old 11-30-2015, 08:21 AM   #1
Air Pressure in rear Air Shocks
Do you guys put any air in your shocks when traveling even when not towing? if so how much?
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 11-30-2015, 08:52 AM   #2
Wandering's Avatar
65 psi seems about right for mine
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 11-30-2015, 09:01 AM   #3
Usually Confused Member
emm-dee's Avatar
I have the Airlift 1000 rear bags and the mfgr specifies 5 psi as a minimum pressure at all times. The wireless controller automatically keeps the system at that pressure.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 11-30-2015, 09:39 AM   #4
trdutch's Avatar
I usually have 50 (set it before I go on a short trip and don't recheck for return)
Mine do bleed down over time but not a lot for 4-5 day trip
I find the coach takes the bumps and dips so much better and handling is better in wind and with passing trucks
I just bought a small rechargeable compressor that will be dedicated to airbags and bicycle/motorcycle/trailer tire service while on the road
Now I will top them off for the return trip
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 11-30-2015, 09:41 AM   #5
A32Deuce's Avatar
You have air bags not air shocks. Just don't exceed 100 lbs.
A32Deuce is offline   Reply With Quote
Old 11-30-2015, 11:45 AM   #6
Do these help with the ride or make it a more rough ride?
Ford F-450
Old 11-30-2015, 11:55 AM   #7
A32Deuce's Avatar
Depends. Load, amount of air in bags. Trial and error. Just don't go under 5lbs. or over 100lbs air pressure. I tow a car trailer behind mine with 2 dogs (150lbs) and 2 adults, depending which car is on the trailer and how long we are gone for, 75 to 100lbs in bags.
Old 11-30-2015, 08:00 PM   #8
Thanks Deuce.
I just took a long trip and don't think I had any air in them.
No wonder she rode so rough, off course the roads sucked as well.
Ford F-450
Old 12-01-2015, 10:07 PM   #9
If you went too long without any air, they may be damaged. Or maybe not..with a little luck they may be ok. See if they will hold air.
jrwalkerpa1 is offline   Reply With Quote
Old 12-01-2015, 11:30 PM   #10
A32Deuce's Avatar
X2!
pressure
