08-18-2015, 06:49 PM
Air ride inflation
So I went to my local service station to adjust my tire pressure and the air ride pressure but it seems the valves on the air ride inflators on both sides of my 3170ds are too short for the connection on the air hose. This is not the first time this has happened, previously at a gas station. My car service guy tells me they sell something that might extend the stem valves, does anyone know how I can fix it so I can get air in the air bags? Thanks everyone for all the help you have been giving me!
08-18-2015, 07:20 PM
I have a clip on air chuck for my compressor and it wouldn't work so I bought the traditional chuck but haven't tried it yet. I have a flow through valve stem cap on my tires, might have to try those on the air bag valves.
http://www.amazon.com/gp/product/B00...=ADX44A2AMJDYO
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
08-18-2015, 07:53 PM
Wait till next year...
Not sure where your valves are on your rig. If in a compartment see if you can tighten the nut holding the valve so more of the valve extends into the compartment. If that doesnt work remove the nut and washer pull the schrader valve out and check that the valve will take air without anything holding it back. if itll take air clean the outside of the compartment where it goes in the hole.Put it back together. If it still wont take air your probably looking at a bad valve or a kink in the airline. Both easy to replace and Firestone has a service kit with parts
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
08-18-2015, 08:41 PM
I had the same problem , couldn't get anymore length changed my air chuck and air pressure gauge now carry my own air source and you can use a bicycle pump if needed just make sure it has enough pressure and hose is long enough most commercial air stations won't work
2015 sunseeker 3050s. 2007 saturn aura
08-18-2015, 09:09 PM
I use a bicycle pump with a clip on chuck. Mine has a gauge on the pump body. A bicycle store is the place to find one. A few strokes is all it takes to get all the pressure you need. Much easier than fighting a gas station air hose.
08-19-2015, 10:17 AM
budblack,
Is there a specific size chuck I should be looking for?
08-19-2015, 10:26 AM
Autozone.
08-19-2015, 10:50 AM
This is what I did. Works well.
I use the pump in the attached pic for both the bags and tires.
$50 at low's
2016 Forest River Sunseeker 3100SS
08-19-2015, 11:49 AM
No just a longer pin in the middle to depress needle valve on air bags easy to find. Couple dollars at harbor freight air gauge the same way
08-19-2015, 12:36 PM
Originally Posted by beachbum107
budblack,
In Bicycle Pump terminology it is Scrader Valve (for size or type of chuck), nicer bike pump will have the guage and the chuck has a lever that locks it on the valve, so it does not pop off, and you can pump hands free.
Presta Valve is a different size chuck --made for the skinny valves of road bikes and now most higher end bicycles(Mtn Bikes, etc).
Many bike pump chucks will have reversable chuck that can work for both types of valves.
I too use my bike pump, much easier than compressor, and only takes a few pumps to top off air ride system, alonbg with having the built in guage.
Markiemark
08-19-2015, 02:39 PM
I agree with Markiemark. A Schrader valve is the standard valve used every car I've ever had, on our motorhome tires, and on the air bags. The bike pump with an attached gauge on the body and a clip-on chuck for a Schrader valve will probably be fifty bucks or so.
08-19-2015, 02:56 PM
Here's such a pump. Needs to have a hose so you can pump standing while the chuck is fastened to the valve.
Charger - | Bontrager
08-19-2015, 03:08 PM
The Schrader valves on mine have about 1 inch of thread and I can expose more of less on the stem by tightening and loosening the locking nuts. See if you can expose more stem so you can get the chuck down tight.
2018 Forester 3011 DS
08-19-2015, 07:12 PM
I think I need a valve similar to what you have. The core valve I have now is not adjustable as far as I know. Once you screw it in and it bottoms out, the stem is to far down and most chucks won't reach it. It's only like that on my inner tires on the rear. The other 4 tires valve stems are just fine.
Oh, by the way, no problem putting air in the air ride valves.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
08-19-2015, 08:35 PM
08-25-2015, 05:46 AM
Had the same problem with my air bags. Went to Les Shwabs to get aired up and the guys just screwed on some valve extenders. Problem fixed. And free!
08-25-2015, 01:01 PM
I shipped my bad manifold back to airlift today for rebuild. Got an estimate of @$90 for rebuild. I'll be so glad to have my wireless system up and running again.
