Old 03-24-2016, 08:25 PM   #1
Air ride question
We have air ride bags on the back area of our Sunseeker 3170. I was wondering what kind of portable inflater do any of you use. It's too expensive to install remote ones and we don't want to be stuck having to go to a gas station. Also, we just had automatic levelers installed. Is there any reason we'd need to adjust the air rises when using the levelers? Thanks for any help. This is new to us.
MzZorro is offline   Reply With Quote
Old 03-24-2016, 08:35 PM   #2
Ford Idaho's Avatar
Some thing like this would be more than enough.
12Volt 150 PSI Compact Air Compressor
Old 03-24-2016, 08:40 PM   #3
Kenny kustom's Avatar
Air ride question
As long as you don't severely change you load, it's kind of a " set and forget thing.
( assuming no leaks either) ..
Check it every once in a while.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-25-2016, 03:25 PM   #4
Hoglou's Avatar
pump it up
A small , very small 120 or 12v pump will do the air bags, but not the tires. It does not take much to fill the bags. Stay below 100 psi...
I actually carry both a small cheap ($20) one for the bags, and an expensive vair 450p for the tires.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-25-2016, 08:47 PM   #5
I have a Viair and really like it. Would get the RV model next time but it is more expensive.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 03-26-2016, 11:54 AM   #6
JimOneil43's Avatar
What is the model # of the Viair Compressor that you use? What is the difference in the one you have and the "RV" model?
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 03-26-2016, 02:21 PM   #7
I have the 300P. The difference between mine and the RV model is mine must be shut off when not inflating. That is, you can't let it run while you move from one tire to the next, it will continue pumping and blow the hose. Most tankless compressors work this way it seems. But the RV model actually has a shutoff. So you don't have to have the compressor right with you while you go around the RV.
Old 03-27-2016, 08:11 PM   #8
Thanks for all the great advice. We don't have a 12 volt outlet in or near the bay's. Any cordless options?
Old 03-27-2016, 08:26 PM   #9
RedLdr1's Avatar
Look for a "jump start box" that has a built in air compressor. You can find them at Home Depot, Lowes, Sears, Walmart, or some automotive supply stores. I have one with a built in flashlight and air compressor that was about $40 on sale after Christmas.
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 03-27-2016, 08:34 PM   #10
Ford Idaho's Avatar
Bet this would reach far enough.
25' 12-Volt Extension Cord - Prime Products 08-0917 - Electrical Cords - Camping World
Amazon might have it for less.
