Old 10-31-2014, 09:59 AM   #1
Mike & Molly's Avatar
Air vent under refer
Why do some 3010DS models have a air vent grate under the refrigerator and others don't?
Mike & Molly is offline   Reply With Quote
Old 11-02-2014, 05:45 AM   #2
The air vent is actually the return air for the furnace. Don't know why some would have it there and others not, except that furnace must be in a different place.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 11-02-2014, 12:33 PM   #3
GM
bclemens's Avatar
We changed the design.
1. We did not like the look of the metal grate. it never matched anything.
2. We found that by putting a gap at the floor and installing a "baffle" (board about 2" behind the floor gap, that was shorted at the top instead of the bottom) the return air flowed into the gap, up and over the baffle and reduced the noise from the furnace considerably.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 11-02-2014, 11:09 PM   #4
mshell56118's Avatar
Could you provide pictures. Would be really interested in possibly doing this on mine
Sent from my iPad using Tapatalk
mshell56118 is offline   Reply With Quote
Old 11-05-2014, 02:49 PM   #5
GM
bclemens's Avatar
There is a gap at the bottom, like a toe kick. Then behind that we box in all 3 sides (so nothing rolls underneath there). Then the furnace is raise up higher than the height of the gap. An even better way is if you use a carpeted board on the back side and run it a little higher yet....but we wanted to make it possible to work on the furnace if need be.
Of course we covered that big front hole with a solid removable panel.
ID:	65896   Click image for larger version
Name:	return air 2.jpeg
vent
