Old 06-17-2014, 05:06 AM   #1
Amps of the lighter outlets
Are these outlets 15 amps?
Sent from my SCH-I545 using Forest River Forums mobile app
GMax is offline   Reply With Quote
Old 06-17-2014, 06:23 AM   #2
I added some of these,they are (Fuse Protected) at 10A! Youroo!!
Old 06-17-2014, 06:48 AM   #3
wmtire's Avatar
If you are referring to the 12 volt accessory plug, like the one you may have in your Winegard antenna booster, it is probably rated for a MAXIMUM of 7.5 amps 12 volts DC.
12 volt DC amps and 120 volt AC amps are different animals.
Here is the Winegard spec sheet and warning:
http://www.winegard.com/kbase/upload/2451486.pdf
WARNING: Do Not Connect High Current Devices to +12 Volt Receptacle
on Wall Plate/Power Supply.
Maximum current ratings of
this receptacle is 7.5 amps at
+12 VDC.
If there are other 12 volt accessory plugs in your RV (not in the Winegard antenna booster plate), they may be a little higher rated, as Youroo showed. You may have a fuse in your control panel that controls it/them.....and that will be your max 12 volt DC amps for it/them.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-17-2014, 06:49 AM   #4
Herk7769's Avatar
If you have one that is also part of your television wall plate it is 8 amps.
Name:	Power Limit.jpg
HAM CALLSIGN - KC3FFW
light
