Old 01-25-2015, 02:05 PM   #11
Originally Posted by bclemens View Post
We used to mount it in the dash area and Ford balked at that. When we were looking for a place we had a retail customer say it would be great if it was mounted on a cord so that if you needed to manually level the unit you watch them come own.
In the end, not many people do that apparently so we're just going to move the controls to the entry way where it is a cleaner look.
That'll work! And I'm sure future buyers will be glad for it.
SkipnTerri is offline   Reply With Quote
Old 01-25-2015, 03:27 PM   #12
JimOneil43's Avatar
Great, Brian. Do you know when that change will be phased into production?
JimOneil43 is offline   Reply With Quote
Old 01-25-2015, 03:29 PM   #13
GM
bclemens's Avatar
Its a running change. Some floor plans are already coming that way. Not sure which ones got done first.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-25-2015, 03:36 PM   #14
Just my 2 cents worth, but I like to be able to stand outside with control box while doing manual level and look at side of MH.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 01-25-2015, 06:55 PM   #15
Regarding auto or manual…
I have the 4 pump auto system done aftermarket at Quadra in Michigan.
After a couple years of use, if I had to redo, I probably would have opted for the 4 pump manual system (although, if I remember correctly, the 4 pump auto system was only a few bucks more versus the 4 pump manual system).
I'd definitely make sure to get 4 pumps vs 1 central pump. For one thing, there are fewer lines running underneath which can only be a good thing. Also, the warranty is better. 4 pump systems come with lifetime cylinder, 2 year parts, 1 year labor. Central pump systems come with 1 year parts & labor.
I find that the auto system tends to forget the "true" level. So you're either re-calibrating every so often or operating in manual mode.
Also agree with the poster above who said auto mode tends to raise the coach more than needed. So, per your comment above that this is mostly for stability vs leveling, I think operating in manual mode (regardless of whether you buy an auto system or not) may be best. Lower to the ground = more stability.
Hence, a 4 pump manual system is fine - unless, as I said, that it's just a few bucks more to upgrade to 4 pump auto system.
Hope all of this makes sense - if not, send me a note back.
P.S., I'm a former hockeytown-er
paulmlac is offline   Reply With Quote
Old 01-25-2015, 07:34 PM   #16
hockeytownmom's Avatar
Thank you, that was very helpful! Mine also be done at Quadra, and I believe the difference is about a thousand dollars. But I've been looking at many RV things this weekend.
Once a hockeytowner, always a hockeytowner! lol
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 01-26-2015, 07:58 AM   #17
GM
bclemens's Avatar
Yes, see there. Problem is, for the 1% that likes that and wants that, I have to explain it to the other 99% that think the corded location is stupid.
Sometimes you just need to let the current take you.
Old 01-26-2015, 08:06 AM   #18
Kaadk's Avatar
Easy solution, just make Bigfoot engineer a wireless remote for them. Then you could leave a cradle by the driver, but let it be take outside for those that want to watch.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 01-26-2015, 08:14 AM   #19
There you go, simple answer to cord problem. I'm sure FR buys enough Big Foot Levelers to have a voice in what they want.
2014 Forester 3051s
2012 Sonic toad
Old 01-26-2015, 08:56 AM   #20
Just for something to read check the sunseeker forum under big foot control box post You can please some people some of the time but not all of the people all of the time
2014 Forester 3051s
2012 Sonic toad
