Old 09-22-2014, 09:55 AM   #11
If you don't run your grill through the MH's external grill connection then yes you will need a reg for the grill.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 09-24-2014, 07:15 AM   #12
Some grills have the reg on it already. Have someone at the rv service store or parts store confirm what you are doing or this blow up in your face. Literally.
Lockwood1976 is offline   Reply With Quote
Old 09-27-2014, 09:15 AM   #13
Thanks for the help got it all hooked up. I can now hook up a low pressure grill a high pressure grill and an external tank.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 09-29-2014, 06:13 AM   #14
Can anyone with the factory grill option on a 3170ds post a picture of where the factory puts the grill mount?
Old 09-29-2014, 07:48 AM   #15
TakeItEasy; you may want to put some sort of support under the regulator (or at the end of reg where main feed line comes out) after looking at mine, I thought that the brass tube of the kit's valve looked like it may break in time with the regs weight and vibration going down the road. Something to think about
2014 Forester 3051s
2012 Sonic toad
Old 09-29-2014, 10:54 AM   #16
GM
bclemens's Avatar
We do not do a grill mount. Although there is a wall mount bracket that ships with the grill (from the mfg) we do not use it. Instead we ship a folding bracket to set the grill on. Keeps it away from the coach just in case.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 09-29-2014, 08:44 PM   #17
Thanks I will probably cut a piece if plastic wood to support the assembly and strap it down.
Old 09-29-2014, 08:45 PM   #18
Thanks now I know why I have not seen a picture of the mount. Now to find a stand.
Old 09-30-2014, 01:09 PM   #19
khocke's Avatar
Regarding a support bracket, here's my Home Depot plumbing & hardware department solution before I reattached my regulator shields
khocke is offline   Reply With Quote
Old 09-30-2014, 02:05 PM   #20
Thanks thats a geat idea. I will be making a stop at the depot tonight.
