09-21-2014, 08:30 PM
Another quick connect question
Just got a 2015 3170. I want to add a quick connect. Looking at the propane tank it looks like the regulator is mounted under a plastic cover in front of the tank. From there it goes into a hose which attaches to a gas pipe with a flare fitting?
I was thinking of taking the flare fitting off the pipe and putting a tee there. I would then reattach the flare fitting and add another flare fitting to feed a hose with a quick connect.
My question is what size is the pipe and flare fitting. I assume pipe is standard black pipe either half or 3/4.
09-21-2014, 09:03 PM
Should be 1/2" NPT. That's what mine are.
2013 Berkshire 390BH
09-22-2014, 02:18 AM
Thanks Campin Cajun
2015 Sunseeker 3170ds
09-22-2014, 05:40 AM
A better option would be to buy a kit that suits your needs. The kit would have all the correct fittings and hose(s). Camping World and other RV supply places sell a variety of them. I can send you links to some if you need them.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
09-22-2014, 05:51 AM
I was looking for kits but did not find what I was looking for. Could be I am looking for the wrong thing. If you have any links that would be great.
It looks like if I order what I need separately it will be right around $55.
09-22-2014, 06:35 AM
Every RV parts supplier I have dealt with offers a line a LP parts and kits by Marshall Products. Here's a link to one supplier. You may be able to find what you need here. If you find what you need but have a preferred RV parts supplier, check for the items you need with them.
RV Products by Marshall Gas Controls - Adventure RV
09-22-2014, 09:37 AM
Takeiteasy I have the same kit on my 3051s and the only thing I found wrong with it is when you are on the external tank while using outside grill and inside stove the performance of the two cooking units is greatly reduced. And yes my tank was full.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
09-22-2014, 09:43 AM
I don't know about the ones you are looking at. I have an Extend-a-Stay to use a grill gas tank to supplement the coach tank.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
09-22-2014, 09:45 AM
Thanks jfrauts, I noticed they have two four port kits. Not sure what the difference is. It looks like the grill would need a regulator in this setup, is that correct?
09-22-2014, 09:55 AM
If you don't run your grill through the MH's external grill connection then yes you will need a reg for the grill.
2014 Forester 3051s
2012 Sonic toad
09-24-2014, 07:15 AM
Some grills have the reg on it already. Have someone at the rv service store or parts store confirm what you are doing or this blow up in your face. Literally.
09-27-2014, 09:15 AM
Thanks for the help got it all hooked up. I can now hook up a low pressure grill a high pressure grill and an external tank.
09-29-2014, 06:13 AM
Can anyone with the factory grill option on a 3170ds post a picture of where the factory puts the grill mount?
09-29-2014, 07:48 AM
TakeItEasy; you may want to put some sort of support under the regulator (or at the end of reg where main feed line comes out) after looking at mine, I thought that the brass tube of the kit's valve looked like it may break in time with the regs weight and vibration going down the road. Something to think about
2014 Forester 3051s
2012 Sonic toad
09-29-2014, 10:54 AM
Commercial Member
We do not do a grill mount. Although there is a wall mount bracket that ships with the grill (from the mfg) we do not use it. Instead we ship a folding bracket to set the grill on. Keeps it away from the coach just in case.
09-29-2014, 08:44 PM
Thanks I will probably cut a piece if plastic wood to support the assembly and strap it down.
09-29-2014, 08:45 PM
Thanks now I know why I have not seen a picture of the mount. Now to find a stand.
09-30-2014, 01:09 PM
Regarding a support bracket, here's my Home Depot plumbing & hardware department solution before I reattached my regulator shields
09-30-2014, 02:05 PM
Thanks thats a geat idea. I will be making a stop at the depot tonight.
