Old 03-23-2014, 03:10 PM   #11
fonzie's Avatar
Originally Posted by VinceU View Post
Always seems that way. Use your 2nd hand to steady the housing while applying the wrench on the cardrige, high up as possible. It's only plastic course thread, it will break free.
Also you can use a hair dryer and heat up the canister at the threads to expand and hopefully release.....
Fonzie
Old 03-23-2014, 03:10 PM   #12
Berkshire 390QS
NO3putt's Avatar
Make sure there is no presure on the filter. What we do is turn off the city water, make sure the pump is off, open faucet until water stops then the filter should come off. Any presure will make it hard and if city water or pump is on when you take it off you will have water spraying all over.
NO3putt is online now   Reply With Quote
Old 03-24-2014, 11:46 AM   #13
Mine is under the bed and I have given up on it too. It's hard to get to and always spills water, so I use a dual exterior filter system both to fill the tank and when directly connected to a water line.
TomG is offline   Reply With Quote
water, water filter
