Old 03-22-2014, 05:05 AM   #1
another water filter question
I'm getting my 2014 Sunseeker 3010DS ready for it's maiden outing, and can't get the canister for water filter loose. I'm afraid I'll break the water line trying to get it loose, it's so tight. Any suggestions?
With chocolate, all is well
richardwise is offline   Reply With Quote
Old 03-22-2014, 05:23 AM   #2
Have you tried a lid opener like that used to remove lids from jars?
This reminds me – I need to change my filter. If I run into problems removing the canister lid, I’ll let you know what I did. In fact, I’ll get the lid opener from the house kitchen just see if it fits.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 03-22-2014, 06:20 AM   #3
slide5r4fun's Avatar
Is the system pressurized? If so, turn the water off, open a faucet and turn on the water pump to reduce the pressure.
If the system isn't pressurized, are you using the canister wrench to loosen? As silly as it sounds, we often turn the wrong way on the canister. If you're facing the canister, are you turning it clockwise?
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is offline   Reply With Quote
Old 03-22-2014, 08:24 AM   #4
Use /look for the filter wrench that should be floating around in the bay with the filter.
Facing filter, slip the wrench so the handle is towards the lefthand side, push.
I get my filters from Amazon in 2-packs. They are regular 10" house filters.
If it breaks, you can replace it also with one from a home improvement store.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 03-22-2014, 09:28 AM   #5
mark0224's Avatar
I use the rubber strap wrench and when I got my trailer the person that put the filter together was a gorilla but this did the job. And as was said they are at most local home improvement stores.
mark0224 is offline   Reply With Quote
Old 03-23-2014, 10:57 AM   #6
Richard, if you have a 2014, why are you changing
the filter so soon?
phelpo is offline   Reply With Quote
Old 03-23-2014, 10:58 AM   #7
VinceU's Avatar
the filter so soon?
Initial installation?
Old 03-23-2014, 02:56 PM   #8
Yes- initial installation. I have a filter wrench, but it seems to just twist the water line trying to loosen. I'm thinking just forgetting about it and use a filter on the hose.
Old 03-23-2014, 03:04 PM   #9
VinceU's Avatar
Always seems that way. Use your 2nd hand to steady the housing while applying the wrench on the cardrige, high up as possible. It's only plastic course thread, it will break free.
Old 03-23-2014, 03:09 PM   #10
Having a fused hip and knee, I can't get back to the filter to hold it, need my second hand to keep from falling over. If it doesn't leak, I'll just leave it alone.
water, water filter
