Old 04-01-2013, 05:43 PM   #11
TURBS's Avatar
Originally Posted by rattleNsmoke View Post
That's a good point. Drain the thing with the on-board pump. You learn something new every day. . Now Turbs, if you're on your back looking at the cannister from the side, do you use a straw for your cocktail?
two straws .......... more suction!
Old 04-01-2013, 05:55 PM   #12
Turn water off, open faucets then i place a short bucket under the filter cannester then use the plastic wrench once the cannester is loose then lower it into the bucket this helps eliminates a spill on the floor it will go in the bucket then remove the bucket with the cannester in it.....once you re-install the cannester ONLY HAND TIGHTEN, DO NOT USE THE PLASTIC WRENCH.....
Old 04-01-2013, 06:02 PM   #13
VinceU's Avatar
Just pretend its a big lightbulb, ya can't go wrong!
