Old 06-02-2014, 02:03 PM   #1
any way to use headphones
Is there any way to use headphones either in the kids zone or front tv?
It would be nice to be able for people in back to listen to their program and driver to listen to radio and not listen to tv.
2014 sunseeker 3170dsf V10
cruiserjohn is offline   Reply With Quote
Old 06-02-2014, 02:42 PM   #2
iluvlcy's Avatar
Plug this into tv or dvd player then plug in headphones!
Name:	ImageUploadedByForest River Forums1401738076.342492.jpg
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 06-02-2014, 04:39 PM   #3
I have a set but get no sound from Tv
Old 06-02-2014, 07:23 PM   #4
iluvlcy's Avatar
Do you have it plugged into audio out not in? We use ours no problem.
Pam & Don
2011 Rockwood 2304s
Old 06-02-2014, 07:41 PM   #5
Most newer TV's have a headphone jack. Try that.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 06-10-2014, 10:32 AM   #6
Jensen has no headphone jack. audio out but no sound when plug in
Old 06-10-2014, 02:20 PM   #7
2012 Solera
2012 Solera "S" with 12 volt Jensen TV. As stated above - no headphone jack. I use an adapter like the one pictured above on the "Audio Output" RCA jacks (have to disconnect the plugs put in the jacks to connect to the dash radio). Then check setup menu on TV - turn speaker "off", set volume to "variable" (not sure of Jensen nomenclature or where in setup menu these options appear - memory says not in same menu section). Then turn up the volume to comfortable earphone volume. Works well on my unit.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-16-2014, 07:16 AM   #8
DMezzoprete's Avatar
I bought a set of two wireless headphones from Walmart.com for $12 and had them shipped to my nearest store for free. They are an excellent way to listen to the TV or DVDs without interrupting the driver or other passengers. They are very easy to install and work great with the Jensen TVs. Each headphone has its own volume control and you can pair as many wireless headphones as you want to the included transmitter. I have pasted the link of the headphones from Walmart below, as well as a picture of the box. Hope this helps! Click image for larger version
Name:	ImageUploadedByForest River Forums1405512990.902127.jpg
Walmart link: http://www.walmart.com/ip/Ematic-Wir...itter/22789489
DMezzoprete is offline   Reply With Quote
Old 07-16-2014, 07:18 AM   #9
By the way, no headphone jack is needed for the wireless headphones. All that is needed are the "Audio Out" jacks, which the Jensen TVs do have.
