Old 05-06-2019, 05:37 AM   #1
Anyone remove the carpet in the bedroom?
I would like to remove the carpet in the bedroom and I am hoping the vinyl flooring in the rest of the coach is under the carpet as well. Has anyone done that? Does the vinyl floor run under the carpet too? Is it in good enough shape if you remove the carpet?
Thanks.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 05-06-2019, 06:28 AM   #2
onetonford's Avatar
If there is vinyl under the carpet and depending on how many staples they used it might be ok. If there is a heat register in the floor you can remove it and see if they put vinyl all the way thru. On my fiver the carpet is the only floor covering they put.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-06-2019, 06:37 AM   #3
A32Deuce's Avatar
I think you will find wood under the carpet that's what I saw in the factory tour.
A32Deuce is online now   Reply With Quote
Old 05-06-2019, 12:58 PM   #4
I agree with Deuce. If linoleum was not originally installed it is most likely plywood under the carpet.
2019 Sunseeker 3010ds
SunseekerFAMof6 is offline   Reply With Quote
Old 05-06-2019, 02:05 PM   #5
oldsmasma's Avatar
Our Lexington is an older cousin to your Sunseeker. We had carpet in the bedroom and living room areas. Pulling a vent in the living room showed wood under the carpet. DH removed the kitchen vinyl and the living room carpet and replaced it with new vinyl. Bit of a chore but what an improvement!
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is offline   Reply With Quote
Old 05-07-2019, 05:55 AM   #6
Ok, will stick with the carpet then.
Old 05-14-2019, 05:51 PM   #7
On my 2011 I can verify that there is no vinyl under the carpet, it is wood. I want to replace the carpet also, but have not made a decision on how to go. The carpet also goes underneath the bed frame cabinetry and under the wardrobe/drawer cabinetry. Have not decided how to handle that either.
2011 Sunseeker 2860
Civic or RAV4 on ACME dolly
PoppySteve is offline   Reply With Quote
bed, roo
