Old 10-06-2013, 04:14 PM   #1
NCIC105's Avatar
Artic pack
Is this something a user can add?
NCIC105 is offline   Reply With Quote
Old 10-06-2013, 04:22 PM   #2
TURBS's Avatar
Yes you can add tank heaters.
Unless your going to camp thru winter at temps below 20 sustained then not worth it imo.
What are your reasons for adding ?
Turbs
Old 10-06-2013, 04:24 PM   #3
NCIC105's Avatar
Turbs
Thanks....We though about doing some winter camping..(A first for us).
But we don't get that much below freezing temps in SC.....
Sounds like we may not need it....
Turbs
Old 10-06-2013, 08:38 PM   #4
Love My Sunseeker
DXSMac's Avatar
The tank heaters automatically come on (if you have the switch turned on) at 40 degrees. On my current RV, the water tanks are in an enclosed area. On previous RV's, the tanks were "exposed" (not in a compartment).
If your tanks are in a "compartment" then a light bulb should work for you if you aren't going to camp at temps below 30.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 10-06-2013, 11:23 PM   #5
Anacortesians
IMO, don't bother. According to the documentation I got (my MH has the system), the built-in, non-adjustable thermostats in the heater blankets switch on at 40F and don't switch off again until they sense 60F. I expected something more like the "Frost-stats" you can get for house plumbing that is susceptible to freezing, on at 34, off at 39.
Who the hell wants to drain 7 amps @ 12 volts for each of four pads to heat the sewage up to 60 degrees? I've disconnected the system on my (used) MH. I have a hard time conceiving of a dumber system design.
Frank and Eileen
No longer RVers or FR owners
Old 10-07-2013, 08:11 AM   #6
Love My Sunseeker
DXSMac's Avatar
Wow, I didn't know about the 60 degree thing. I figured it would shut off at, oh..... 45 degrees. And yeppers, you have to figure in the tank heaters in the amperage count.
Old 10-07-2013, 08:26 AM   #7
mjones12's Avatar
Turbs
Agreed. We camp all winter in North Carolina without heated tanks. Our dealer's service department talked us out of adding $800 heated pads. Told us that unless the tanks are full with no space for expansion, freezing won't hurt anything, anyway.
We have never had problems with this in 8 years of camping all winter. As you say, unless the freezing tempeatures are sustained, not much to worry about. We just detach (and empty) fresh water hose at night and hook back up the next morning. Never a problem despite some nights down to 15 or 20.
We leave our gray tank valve open when we have hookups, and everything we put in the black tank is 98.6 degrees LOL. If it does freeze, we'll dump it when it thaws out. But it never has.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 10-07-2013, 08:28 AM   #8
Usually there's a switch on them so you don't have to use them if you know its not going to be cold.
Old 10-07-2013, 08:37 AM   #9
Taylorgso's Avatar
And if you're concerned about them staying "ON" until temp reaches 60, just reach up and turn the switch off when you're satisfied the temp is not going to drop again! My valuable $.02 worth!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 10-07-2013, 09:29 AM   #10
GM
bclemens's Avatar
Not to mention the Sunseeker come with heated and enclosed tanks anyway. If you're running the furnace in cold weather, you're heated the tanks in cold weather.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
