Old 03-01-2015, 06:06 PM   #1
Auxiliary Braking
Is anyone using an auxiliary braking system like BrakeBuddy? If so, what are you using and why do you like/dislike it?
2012 Sunseeker 2450S
2015 Jeep Wrangler Toad
SilverSunseeker is offline   Reply With Quote
Old 03-01-2015, 07:13 PM   #2
Hoglou's Avatar
Patriot
Patriot and like it. I really like the remote gain control in the cab. you need 12volt to run it. I keep power to the toad battery from the coach so I dont rely on the internal battery....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-01-2015, 07:50 PM   #3
Average Joe
MrJoe's Avatar
I also use the Patriot and works well for us. Very easy to use. I haven't needed to run power from the coach to the toad. We usually run 7-8 hours a day and never had a power issue with the toad. We also use the wireless TowMate TM3 lights.... super quick and easy to setup.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 03-02-2015, 09:31 AM   #4
INVISIBRAKE
Works great.
Kevin & Judy is offline   Reply With Quote
Old 03-02-2015, 09:58 AM   #5
I like Ready Brut tow bar with integrated surge brake system. Simple system and no electrics to worry about.
RV Tow Bars - NSA RV Products
ATVer is offline   Reply With Quote
Old 03-02-2015, 10:57 AM   #6
We have a Patriot and like it. The car battery will run it two and a half days. Used a booster battery for the last half day.
Rarely get false applications, usually when going over rough railroad crossings.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 03-02-2015, 11:10 AM   #7
ATVer just watched that video looks like good unit, only question I have is on a vacuum assist brake system of your towed vehicle after one or two applications it becomes REAL!! hard to apply brakes, will that cable still apply with enough force to apply brakes in towed vehicle ?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-02-2015, 12:14 PM   #8
Hoglou's Avatar
Brake buddy and a patriot
I also use the other kind of brake buddy. This is about the size of a match box. It allows coach power in, but will not allow power to go from the toad to the coach.... This keep the toad topped off.
BrakeBuddy 39332 Towed Vehicle Battery Maintainer
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 03-02-2015, 11:05 PM   #9
Garrette's Avatar
Rvi2 with the TPMS system. Works well. Small lightweight.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 03-02-2015, 11:35 PM   #10
Brewster McFrisk's Avatar
I use the Patriot and so far it has been flawless! Works great with the gain control and keep the toad battery charged with a small charger powered by the RV. You can run the Patriot over a day and a half on its own external battery before charging. I added a extra fused power adapter that's wired directly to the battery when I want to charge it or just leave it plugged in all the time.
Brewster McFrisk is offline   Reply With Quote
