Old 03-25-2019, 08:32 AM   #1
awning
Have a 2013 sunseeker 3050s and went to roll out awning and nothing, checked to have power at switch and do, but unit fails to roll out. Is there a inline fuse in the system. we have power outages during the winter and that could of blown the fuse. checked the cabinet with all the tv stuff but no fuse there nothing outside and can not get at motor as unit will not roll out .
oldnewguy is offline   Reply With Quote
Old 03-25-2019, 08:47 AM   #2
Did you check for power at the wires at the awning arm/motor or where they go through the wall when someone depresses the switch?
Fuses typically protect the feed wire and if you have power at the switch the feed is OK. There would be no downstream fuse going to the motor unless someone added something aftermarket.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 03-25-2019, 09:21 AM   #3
Garrette's Avatar
It will not roll out if engine is running also, make sure it is in Park.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 04-01-2019, 02:00 PM   #4
Check by the awning arm where is comes out of the body, as there is a plug in for the power wires, Mine came unplugged once. Plugged it back in and put a small ty rap around it so that could not happen again.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
awning
