Old 05-31-2013, 01:30 PM   #1
Mike & Molly's Avatar
Unhappy Awning Cleaner
Got some stains on the awning that look like rust streaks.
Bought a cleaner the dealer recommended call Martins "Extra Duty"
Totally useless.
Can anyone recommend a good safe awning/vinyl cleaner?
Thanks.
Mike & Molly is offline   Reply With Quote
Old 05-31-2013, 01:41 PM   #2
Golflover's Avatar
Totally useless.
Thanks.
I've used Purple Power. It does a good job on awnings and black marks on the camper. You can get it at hardware and auto parts stores. If you have rust spots CLR might be the thing to use. I would try diluting it first before using it full strength. I use that to get the hard water and rust spots off my tub and some other metal objects. Never tried it on an awning though...
Golflover is offline   Reply With Quote
Old 05-31-2013, 02:23 PM   #3
lindy's Avatar
X2 on the Purple Power, or just a bleach/water solution. Climb up on the roof of the camper with the awning extended. Soak the awning down and then roll it up for about 1/2hr. Unroll and use a brush on any stubborn remaining stains, and rinse real good.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 05-31-2013, 02:34 PM   #4
osgood's Avatar
I really like the cheap route here. 2 gallons of water and half cup of bleach.... Brush on, roll up, wait 20 min, un-roll, rinse off and brush some stains again if needed
osgood is offline   Reply With Quote
Old 05-31-2013, 02:54 PM   #5
trudinator's Avatar
I used dollar store Awesome cleaner on mineworked like a charm. Sprayed it on full strength, than brushed itclran, and rinsed it off. But I'm in the category of "never volunteering to clean the awning again club". Messy and WET job.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 05-31-2013, 03:19 PM   #6
fivecodys's Avatar
X2
You can also use Tilex on the really bad spots.
Spray, Roll up, wait 20-30 min, unroll and rinse.
I have been using both methods for years now.
Bill
2009 Flagstaff 8528 RKSS
2019 GMC 2500 HD Diesel
Pullrite Superglide 14K
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 05-31-2013, 06:55 PM   #7
Plain Old Member
X's whatever number we're on. We use bleach / water sometimes, but mostly purple power. Spray on, roll up, 15 minutes, roll out, wash off. If we wait too long in between washes, sometimes ill scrub a little after its soaked. We do the same on slide tops.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-31-2013, 11:09 PM   #8
Triguy's Avatar
I've heard good things about Purple Power, but Awesome is... just awesome!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
