Old 06-07-2016, 12:09 PM   #1
Awning help
I have a 2013 sunseeker 3010ds and I noticed my awning was slightly out, so I went to check on it. My switch want wasn't working. I checked the fuse by the steps and it looks ok. What else can I check?
bikeit02 is offline   Reply With Quote
Old 06-07-2016, 12:50 PM   #2
RV was not running was it? I had mine out, and it wold not go in until I turned my engine off. Just throwing that out there.
desant89 is offline   Reply With Quote
Old 06-07-2016, 09:34 PM   #3
The awning on our 2012 3170 stopped working. After taking the awning drive system apart, which did not fix it, I determined the switch had stopped working. Should have checked for power at the switch first. I took the switch apart, lubed it with grease, put it back together, and it now works. If you do take the switch apart, be sure you label wires and switch inputs. You can figure it out without doing that, but labeling before disassembly is a lot easier.
budblack is offline   Reply With Quote
Old 06-11-2016, 11:23 PM   #4
awning not working
I checked the fuse at the campground and it was the problem. Thanks for helping with this problem. Dale.
awning
