Old 05-27-2018, 06:55 PM   #1
Awning led lights
About half on my led lights on my awning, what do I need to replace them?
Mike3393 is offline   Reply With Quote
Old 05-27-2018, 08:12 PM   #2
Just as confused as you
Scrapper's Avatar
You will have to replace the complete length. You can go to any rv dealer, camping world, walmart, or amazon and get the length you need. They are 12VDC unless you have the multi-colored strip then it will most likely be 24VDC with a controller.
Richard & Jill
Old 05-27-2018, 08:30 PM   #3
Nurek's Avatar
RGB is not necessarily 24VDC.
I've installed hundreds of meters on different vehicles using 12VDC no problem. Even my own.
There are many things to consider when replacing a light strip. Width of channeling, wire routing, do you want SMD? 50/50? RGB50/50? 3528? COB? Termination points? IP68 or nah?
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 06-06-2018, 08:40 PM   #4
Mike, did you have any luck replacing it? Mine is probably 1/2 out as well. I’ve looked but don’t see how the lights are hooked into the wiring. I don’t won’t to go ripping out a bunch of stuff for just a string of lights. But if someone says it’s easy...
johnlantz is offline   Reply With Quote
Old 06-06-2018, 09:11 PM   #5
Kasual Kamper
Are aftermarket LED lights available that just slide into the awning track?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 06-06-2018, 09:13 PM   #6
Stuck ours on the camper itself under the awning attaching rail.
Old 06-06-2018, 09:39 PM   #7
deartruc's Avatar
Highly recommend these: https://www.banggood.com/Wholesale-2...?rmmds=myorder
They just slide right into the track after you slide the old one out. For $10, you also get color.
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 06-07-2018, 02:23 PM   #8
Try Super Brights. Replaced 3 sets of the OEM style lights in 2 years, The super brights are now on 2 years and doing great.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 06-11-2018, 12:13 PM   #9
Place lights on the side of the HM, use the switch to control them. I am Planning to do this on mine. Mounting them on the roller does not make sense to me or the DW.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
FrankMor is offline   Reply With Quote
Old 06-19-2018, 09:01 PM   #10
Replaced with set from Wally World about $10: took about 15 minutes!
Old 06-21-2019, 07:03 PM   #11
I'm looking to replace my set, three quarters of the lights are out. The one link provided seemed to have an adapter that the lights we plugged into. The RV lights are hard wired into a 12 volt connection.
Could someone send a link of something they bought that replaced what is there already on the Sunseeker?
Old 06-30-2019, 05:00 PM   #12
Hoglou's Avatar
SUPERNIGHT (TM) 5M Waterproof 5050 SMD 300 Epoxy LED Strip Light White
by*SUPERNIGHT (TM)
These specific ones may not be avail as I got tnem two years ago on amaz. Any 5 meter water proof will work..
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
awning, led, light, sunseeker
