Old 04-29-2015, 01:28 PM   #1
Awning on 2010 3100ss sunseeker
Took our MH out for first trip of 2015. Discovered that our power awning will not extend. When we push the button nothing happens: no clicks, no sound, no motion.
We are wondering if we blew a fuse but cannot find where it might be. Does anyone know where the awning fuse may be located?
Thanks,
Shirley
shirleyj62 is offline   Reply With Quote
Old 04-29-2015, 02:39 PM   #2
Class C Representative
Joshua Cavitt's Avatar
In the fuse panel that is almost always located on the bed.
Joshua Cavitt is offline   Reply With Quote
Old 04-29-2015, 02:44 PM   #3
bubbles's Avatar
Not familiar with your unit but typically powered awnings are fused (15AMP) directly off the battery post. That way it can always be retracted even if a battery disconnect switch is used.
Old 04-30-2015, 02:12 PM   #4
We have a 2011 model 3100. The awning fuse and relay are in the Battery Control Center beside the step.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 05-01-2015, 06:40 AM   #5
trdutch's Avatar
As a side note
I'm not sure whether you saw my lengthy thread on my awning problems (popping the 15 amp breaker) but it magically stopped popping breakers for the dealer shop
The conclusion I came to was my battery bank was low on water and of course not holding a full charge and I'm wondering now if the breaker was only popping when I was trying to move it with battery power (shore not yet supplied and or testing without shore power plugged in or plugged into the house for servicing and circuit overloaded.
Battery is serviced and awning works fine now but I don't really have a need to move the awning without shore power so no more problems
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 05-05-2015, 06:35 PM   #6
Just a random thought, had you already started the engine? We did this once, my husband had started engine and I went to put in the awning- nothing! Panic! Until we figured it out, turned off the engine and it worked! Maybe a safety feature?? But who would drive with the awning out!! We have a 2011 Sunseeker 3010
Todayray is offline   Reply With Quote
Old 05-08-2015, 07:23 PM   #7
Garrette's Avatar
Yep, truck will not start if awning is out.
Garrette is offline   Reply With Quote
Old 05-08-2015, 07:35 PM   #8
[QUOTE=Todayray;855557 But who would drive with the awning out!! We have a 2011 Sunseeker 3010
Sent from my iPad using Forest River Forums[/QUOTE]
Thats why most rental MH's don't have awnings
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
3100ss, awning, sunseeker
