Old 07-28-2016, 01:19 PM   #11
Check the outside track along the wall sometime it will close to tight, if not it could be the electric motor on the awning that about $375.00 for that little motor, good luck...🖒
goots is offline   Reply With Quote
Old 07-29-2016, 07:36 AM   #12
trdutch's Avatar
Originally Posted by Bednarski1 View Post
I have the same unit but that has never happened to me. Did you check your battery? Is your battery disconnect switch on?
Bad batteries that were not holding a charge caused my awning fuses to pop
I had every suggestion under the Sun including install new motor and listen to this one,put in a higher amp fuse (don't do that)
Finally a mobile repair guy figured out my batteries were the problem
Two new Interstates and I have never had another problem.
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 07-29-2016, 08:04 AM   #13
Great news, Happy Rving 🖒
Old 07-29-2016, 04:41 PM   #14
Good news turns out it was covered under recall Dometic is sending a mobile RV guy to our location to put the new motor in awning. Thanks to everyone who replied and tried to help us out
kitejunky1 is offline   Reply With Quote
Old 07-30-2016, 01:55 PM   #15
Do you know which models were under a recall from Dometic? How did you find out about the recall?
ActionJackson is offline   Reply With Quote
Old 07-30-2016, 03:21 PM   #16
I found this post.
ID:	115836   Click image for larger version
Old 07-30-2016, 03:35 PM   #17
^^^^ Thanks.
awning
