Old 07-23-2016, 03:07 PM   #1
Awning will not extend.
I have a class C 3010DS the awning will not extend I hear a clicking noise when I hit the button but nothing's happening anybody else ever have this problem what should I do first check the fuse?
kitejunky1 is offline   Reply With Quote
Old 07-23-2016, 03:21 PM   #2
I have the same unit but that has never happened to me. Did you check your battery? Is your battery disconnect switch on?
Bednarski1 is offline   Reply With Quote
Old 07-23-2016, 03:52 PM   #3
fuse is good, plug into shore power, house battery switch on.
Old 07-27-2016, 11:09 AM   #4
skylilymd's Avatar
What year is it ? Is it a dometic awning ? When you hit the switch do you hear a click from the awning motor or a click from inside the vehicle ? Check the fuse and if the fuse is good here is what I found with mine. If you open the panel in the foot well you will see the awning fuse and right next to it is a wire coming out of the circuitboard. I don't know if you have a circuit tester but what I found on mine is that even though the fuse was good there was no power coming out of the wire next to it to go to the awning motor so there was an issue with the little board but fortunately there are a bunch of empty fuse sockets so I simply moved it down to the next one and swapped the wire down with it and awning works fine. This would only apply if the clicking you hear is not your awning motor trying to move it out
skylilymd is offline   Reply With Quote
Old 07-27-2016, 06:13 PM   #5
NORCALRVing's Avatar
Is the engine running while your attempting to do this?
I noticed when my engine is running I cannot operate the awning.
2011 3010
NORCALRVing is offline   Reply With Quote
Old 07-27-2016, 06:17 PM   #6
SeaDog's Avatar
Let us know what you do to fix the problem
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-27-2016, 06:22 PM   #7
ilmor's Avatar
How old?
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-27-2016, 07:04 PM   #8
Its a 2013 and yes it's a Dometic awning.
I was hearing a clicking when operating it but now I don't hear a click at all.
Old 07-27-2016, 07:37 PM   #9
2013 Dometic- fuse is good. I was hearing a clicking but now I don't.
Old 07-28-2016, 05:35 AM   #10
ilmor's Avatar
I think there's an electrical connector near the motor. If so would you be able to disconnect it and use a meter to see if it's getting power when the button is pressed? If it is then the motor must be bad.
awning
