Old 06-05-2016, 04:20 PM   #1
trdutch's Avatar
Backup Cam went White
Monitor seems to be working (menu functions and reverse grid in place) but screen is all White
Bad/loose connection?
Camera failure?
Any Ideas?
Calling the shop tomorrow
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 06-05-2016, 04:45 PM   #2
Sagecoachdriver's Avatar
Is your system like this in the photo? If so, check the connections on the multiplexer located behind the pull-out panel under the steering wheel. It should be on the left side probably behind wire. Make sure all the connection are tight and then you can scroll thru the monitor cameras and switch the connector around to see if you have a bad camera.
Most of us have encountered a blue screen with NO SIGNAL, haven't run across a white screen. You can call RVS who makes this system and they have good tech support.
Here's the manual also, http://www.rearviewsafety.com/media/...n_lowres_1.pdf
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-05-2016, 05:19 PM   #3
trdutch's Avatar
Thanks, Ill get started troubleshooting
'78.....tents
Old 06-05-2016, 05:40 PM   #4
FYI, if you have mirror mounted cameras, they are from another manufacturer ASA Electronics. RVS system has proprietary cables and the ASA side cameras have an extra rewired cable so as to connect with the RVS system. It's between the end of the mirror camera cable in the arm and runs to the multiplexer.
Also, have you tried adjusting the brightness and contrast? Also, read the manual about doing a system reboot by disconnecting the power cable for a while.
Good luck and please keep up posted as others may have the same issue in the future.
Old 06-05-2016, 08:48 PM   #5
Whiteknight's Avatar
Is it white at night also? If it seems okay or at least better at night I would guess that the camera auto iris is bad. Will probably have to replace the camera if rebooting/removing power doesn't fix it.
2012 Flagstaff V-Lite 30WFKSS
2015 Ram 2500 Big Horn Mega Cab 4X4
Whiteknight is offline   Reply With Quote
Old 06-06-2016, 07:43 AM   #6
trdutch's Avatar
I think I'm going to have someone look at it
Who? is the question
I'd like to try the reboot (even though that's under the Blue screen display problem) but when I got under the dash I really couldn't identify the control box
I was tired after driving all day
'78.....tents
Old 06-06-2016, 12:57 PM   #7
Thanks Sagecoachdriver for the RVS link. I have seen the white screen once and blue a couple of times but camera is working for now. Anyone know where the multiplexer is located on a Solera?
jamesarnold is offline   Reply With Quote
Old 06-06-2016, 06:10 PM   #8
The camera is an RVS. They have extraordinary tech support and should be able to help trouble shoot and give some answers. The tech support number is 800-764-1028. They are located in California.
PenJoe is offline   Reply With Quote
Old 06-07-2016, 09:07 AM   #9
trdutch's Avatar
So far I've found the multiplexer
Reboot
No change
Switched cable to other two unused inputs
Screen goes from blue (normal unused) to white
The red infrared light on the camera is illuminated
So......,
Either the camera (Iris) has failed,the camera cable/connection is bad, or the 20 something foot cable is bad
Trying to get it into a shop before ordering parts
'78.....tents
Old 06-07-2016, 11:18 AM   #10
Suggest you call tech support at
Customer Service: Rear View Safety Tel: 1.800.764.1028
Your model could be RVS-770619N
Do you have side mirror cameras? If not , only the backup camera port will be operational for testing as there in no trigger wired for the turn signal. But it may work scrolling on menu.
Also, reading up on CreativePar'st thread may help. Intermittent camera? Or monitor?
