Old 02-14-2016, 04:59 PM   #1
batteries discharging
Both my batteries have discharged the coach batteries are brand new and where isolated by switch ... vehicle battery was used Dec to start vehicle with no problems ... this is the 2nd time that both batteries have been completed discharged... any suggestions where to look
Allan
comox is offline   Reply With Quote
Old 02-16-2016, 01:27 AM   #2
benagi's Avatar
Allan
I had that problem with our 3171 Forester. Same as a 3170 Sunseeker. Found out there will always be a small drain on your batteries, even if the switch is off. The only way to keep your batteries from going dead if you don't have shore power hooked up or a battery tender on, is to disconnect the negative cables. Since I have done that, my batteries are now holding a charge. Good luck with yours.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 02-16-2016, 01:58 AM   #3
Bluepill's Avatar
^^ THIS
Make sure that the batteries are fully charged and equalized before storage, and they can easily stay above 50% SOC for 90 days in cool weather.
Old 02-16-2016, 02:04 AM   #4
benagi's Avatar
Originally Posted by Bluepill View Post
^^ THIS
Yes, Bluepill is correct. We had ours fully charged before disconnecting the neg. cables. It's been 3 weeks now in cold weather and the batteries are still looking good.
1968 tent trailer
1985 Jamboree 23 ft
Old 02-17-2016, 12:29 AM   #5
Delco Bobby's Avatar
Allan
In addition to the other replies you may have a TV and other devices that work on DC. If so unplug them. The front TV on my Sunseeker work on DC and was a drain on the battery. Also, the Magadyne radio is a current drain.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 02-17-2016, 02:06 AM   #6
benagi's Avatar
Everything in our unit runs on DC except the A/C and microwave which are 110. Most all the DC equipment if powered on will power down when your main switch is off. When our unit was tested at CW for things draining the battery with the switch off, it was only our Bigfoot jacks. That was enough to completely drain the batteries in a week. When not on shore power and the unit is in storage, I disconnect the negative cables . All is good now.
1968 tent trailer
1985 Jamboree 23 ft
Old 02-17-2016, 02:12 AM   #7
flymhi's Avatar
try these....
I have these on my boat and they work great with no tools required for disco/reconnects. They make them for the fat post and screw-on post. about $3-6 each. Search for "battery quick disconnect" on ebay or amazon.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 02-17-2016, 02:14 AM   #8
benagi's Avatar
Nice, I'm going to get me a set. Thx for posting a picture .
1968 tent trailer
1985 Jamboree 23 ft
Old 02-17-2016, 04:41 AM   #9
Be sure the disconnects are rated for at least 200 amps. You don't need that much normally but you do if you use the battery booster switch to start the chassis engine.
Also, if you are boondocking, switch off the antenna amplifier when you are not watching TV. It takes a little current constantly. If you boondock much, disconnect the refrigerator "Climate Control" element. It stays on all the time. There are several threads in the FROG forum about it .
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
charging, battery
