Old 07-18-2016, 01:03 PM   #1
Batteries dying in New 2016 Forest River Forester
Hello All
New to the forum but such a helpful site!
Just wondering if we are doing something wrong with the batteries. We have found that they don't last very long and trigger the alarm for low battery.
We will charge them up before leaving on a trip (attached to electrical at the house) then likely drive an full 8 - 10 hour day. Once we stop we may turn on lights for a short time, but are conscious of using any power. Don't use the microwave or what we think are power using things. We are always finding that the battery alarm will go off about 4 hours after we stop driving. The only thing that may be running seems to be the fridge although it is on gas but it seems it still takes some electrical. We turn off all the lights, no A/C or TV running.
Do we need to replace with better batteries or perhaps there is something wrong with the ones we have? The unit is only 6 months old. Sadly our dealer doesn't seem to have any answers for us.
Any suggestions would be welcomed.
DNOLB is offline   Reply With Quote
Old 07-18-2016, 01:14 PM   #2
Flybob's Avatar
There are several items that use DC power when the battery is connected. The fridge uses 12V to operate the control board. Also some of the larger fridges have a 12V heater strip between the freezer door and the fridge door. That draws a reasonable amount of current. The alarm you are hearing is technically not a low battery alarm, it is the CO/Propane detector letting you know that the voltage is too low for it to operate properly. It is also possible that you are not starting with a full battery or the battery has been discharged too low and charges, but will not supply full capacity. Do you have a fridge fan? Either inside the fridge or in the roof vent.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-18-2016, 01:22 PM   #3
ilmor's Avatar
Originally Posted by DNOLB View Post
Hello All
You may have bad batteries. Do you have two? If one battery is bad it will also draw from the other.
After charging them while connected on shore power, read the voltage using a voltmeter. You should see 12.5 or 12.6 volts if fully charged. If that's the case then it appears the converter / charger is ok.
If they're still fully charged after you drive the 8 or so hours, then your chassis alternator is also charging them ok.
I would remove the batteries and take them to an Advance Auto Parts, NAPA or similar where they can be tested. Rule out whether or not the batteries are bad.
If they're bad, see if they are covered under your (assumed) 12 mo. Forest River warranty. I don't think they are, unfortunately. But at least you'll know.
If they're good, then something in your coach is sucking life out of them. A/C's do not use battery. I was thinking in that case I would pull all 12 volt fuses, then wait an hour before re-inserting each 12 volt fuse to see if you can isolate the culprit. If there's one for the fridge turn it off first before pulling the fuse.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-18-2016, 01:35 PM   #4
If they're wet cell, be sure to check water levels in the batteries.
latner is offline   Reply With Quote
Old 07-18-2016, 02:18 PM   #5
ilmor's Avatar
Good point! I just got a 2017 and I'm going to check mine! RV manufacturers don't usually install the best batteries in these things as it is.
Old 07-18-2016, 03:24 PM   #6
17Racer's Avatar
Well it is either low water in the batteries/bad batteries or something is draining them
2 things you might check first are.
Do you have a closet with a light that is turned on by opening the door? And does it shut off when closed? Mine was not shutting off as it should.
If you have basement lights in a couple cargo areas are they shut off? They can be left on by mistake and not seen.
2014 Forester 2301 - Chevy
17Racer is offline   Reply With Quote
Old 07-18-2016, 04:31 PM   #7
Thanks so much
This forum is amazing. Thank you so much for your replies, we will check all of the suggestions to see what is going on! I would just like to solve the problem so as not be woken up in the middle of the night to the lovely sound of the alarm!
Here's to better sleep.
Old 07-19-2016, 12:37 PM   #8
Hello All
I had the same problem when I first used my new 2014 Sunseeker. The dealer received the RV in the fall of 2013 and sold it to me in the spring of 2014. The intervening winter was brutally cold. I am convinced that the RV was not plugged into electricity over the winter. It may even be the case that the main on/off switch was left on. When a load test was performed on my batteries they proved to be bad. After new batteries were installed I had no problems what so ever.
papakilo is offline   Reply With Quote
Old 07-19-2016, 12:54 PM   #9
trdutch's Avatar
The Batteries in My 14 were junk and caused all sorts of problems
The manufacturer gave me a pro rated rebate $100 or so back
I dropped in Two Interstates and life is good again
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 07-19-2016, 01:11 PM   #10
gizmo98's Avatar
I had the same problem last week with my new forester river class c 3051S
alarm went off about 4 1/2 hours after I turned in for some sleep. I accidently left the led awning lights on plus the outside porch light and the trail lights. it drained the battery causing the alarm to go Off I ran the generator for about an hour the batteries kept the charge then drove again to the the RV site
Rob & Elizabeth Sweeney
Having fun in our Forester Gump (2015 3051S forester)
gizmo98 is offline   Reply With Quote
forester, battery
