Old 11-22-2015, 09:54 PM   #21
I have a 2014 Sunseeker and my batteries are pretty much shot according to a RV tech that checked them out. He was being honest with me as he did not sell batteries. I think cheap 12 volts are put in by FR and I am not sure they are deep cycles to begin with. To boot I think the person who owned prior to me only used it for a couple of tailgate games and didnt really take care of it. I think I am going to end up going with 2 6 volts and hook them up in series vs the 12 volt in parallell. That seems to be what a lot of folks recommend.
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 11-23-2015, 09:41 AM   #22
2012 Solera
If your batteries are under your entrance step, be sure to verify the battery height vs the available height. I understand golf cart six volt batteries are too tall for our Solera without some modification.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 11-23-2015, 07:30 PM   #23
Thanks for the heads up, I am going to measure before I buy
Ford F-450
Old 11-30-2015, 08:50 PM   #24
Delco Bobby's Avatar
Originally Posted by Jim Schings View Post
No. Too many variables. I would just measure the voltage on the batteries in both conditions....
I finally got around to putting a volt meter on my battery as per Jim Schings and also used ATVers suggestion.
The RV was on shore power for 5 days and the battery switch in the on position. Then it was unplugged for one day with the battery switch off and the TVs unplugged. At that point the battery voltage read 12.36 volts and the lights on the battery monitor indicated 1/3 charge.
Today, after another day of being off line and the battery switch in the off position the volts read 10.34 and the red battery lights showing empty. After that I started the engine and let it run for about five minutes and the voltage read 14.51. A previous time all the lights were lit up on the battery monitor with the engine running.
Then I turned off the engine and plugged into shore power. With the battery switch off off it showed 13.02 volts and with the battery switch on it showed 13.48 volts.
Correct me if I am wrong but I believe my battery is toast despite what my dealer claims based on their $55 battery test.
BTW, there is plenty of room in the battery box under the step for two batteries that are larger than the current group 27. A quick and not precise measurement shows 9.5 inches of height and about 28" in length.
BTW2, When we bought this RV last August among the things left by the previous owner was an unidentified strap. I saved the strap but had no idea what is was for. A couple of people at the dealership also had no clue. It matches exactly the strap that holds down the existing battery. Mystery solved.
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 11-30-2015, 10:19 PM   #25
O'Reilly Auto Parts will test your battery for free.
budblack is offline   Reply With Quote
Old 11-30-2015, 10:40 PM   #26
even turning the battery switch off, there are still parasitic loads that can drain the batteries. disconnect the cables, charge the batteries, wait at least 12 hours to test.
leaving shore power on for five days will boil batteries dry. if I'm plugged into power I always leave a light or two on to keep the cheap converter from killing the batteries. after a trip I check/top off levels, charge and disconnect completely.
poorbuthappy is offline   Reply With Quote
Old 12-02-2015, 12:23 AM   #27
benagi's Avatar
Poorbuthappy, I've seen on other threads that some people leave their rv's plugged in all winter and never had a problem with boiling batteries. Can someone chime in on this who leaves their unit plugged in when stored? Thx.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 12-02-2015, 04:10 AM   #28
MarsMan's Avatar
Coachmen factory rep advised me to not store my MH with the converter charging the batteries. They suggested disconnecting the battery at the negative terminal (to remove all parasitic load), make sure fully charged and then either remove and store at home OR leave in MH and place on a maintainer.
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 12-02-2015, 09:24 AM   #29
trdutch's Avatar
If you tripped the Converters breaker,
Wouldn't that prevent charging and you could still leave it plugged in to run Electric heater?
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 12-02-2015, 10:52 AM   #30
Jim Schings's Avatar
Possibly
Then you have a problem with the system. You can (and many people do) leave it on shore power for years. Of course you should check the water level periodically like in any use.
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
Jim Schings is offline   Reply With Quote
battery
