Old 05-24-2015, 11:43 AM   #1
Battery Maintenance
I have had my sunseeker 3170 for a year now and decided to check the batteries. What am I looking for exactly. I keep reading to make sure that the water level is 1/8 to 1/4 inch above the plates. I do see water covering the plates (I see silver under the water). The water is barely covering them. Should I add distilled water? If so, how high should the water level be?
Thanks,
Jeff
Jlklingejr is offline   Reply With Quote
Old 05-24-2015, 12:32 PM   #2
fonzie's Avatar
Add distilled water to just below slot in openings.......
Fonzie
Old 05-24-2015, 01:19 PM   #3
Perfect! That's what I needed. Thanks.
Old 05-24-2015, 02:36 PM   #4
I keep water in my batt just under the plastic on the caps, which is about 3/4 from the top of the caps. Use distilled water not tap water. I check mine monthly on the 1 st of each month. If not sure auto stores cell batt fillers cups that u stick in the hole once it get full water stops flowing.
cfiowa is offline   Reply With Quote
battery, maintenance
