Old 09-03-2015, 10:04 AM   #1
battery over charging on shore power
I have a 2014 3170ds with two batteries and when on shore power the front one get very hot and boils the water out. what controls the charge rate ?
John and Diana Embrey Texas 2019 Coachmen Mirada 35 KB
cruiserjohn is offline   Reply With Quote
Old 09-03-2015, 10:11 AM   #2
2012 Solera
Converter controls charge on shore power. However, your issue sounds very similar to the battery problem noted in this thread:
http://www.forestriverforums.com/for...hot-91536.html
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-03-2015, 10:13 AM   #3
TURBS's Avatar
Sounds like a bad battery.
Replace them in pairs.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 09-03-2015, 10:23 AM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
The charge controller / converter takes care of charging the batteries, many better quality c/c's are programmable for the battery type: Flooded, AGM, Gel.
If you find you have a problem with one battery being overcharged,
1. unplug the trailer from shore power,
2. let the batteries cool down,
3. check both batteries are identical
4. check battery voltage with Voltmeter
When working with batteries there are a few rules:
1. wear acid resistant gloves and safety glasses when handling questionable batteries
2. Never tip batteries over, unless they are sealed AGM type batteries
3. When connecting batteries start with positive cable then negative, when disconnecting negative first positive second.
Do get to your main question, it is very possible that the battery that's boiling is just defective and needs to be replaced. A fully charged battery should have 12.6 - 12.9 Volt when left disconnected for about 30 minutes to an hour, if it is less you have a brick.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 09-03-2015, 11:58 AM   #5
rsdata's Avatar
since you say it boils the water out are you replacing the water with distilled H2O?
2014 Shamrock 183
Old 09-03-2015, 12:25 PM   #6
mguay's Avatar
The same thing happened on my last 5er. One of the 2 batteries would boil over. At first I thought it was one bad battery. But after calling WFCO I figured out that the converter was bad. It was putting out 14.8v. It was just enough to boil the first battery and not the second. I replaced it with a BoonDocker.
2015 GMC Denali DRW
2014 Dynamax Trilogy 3715FB
mguay is offline   Reply With Quote
Old 09-03-2015, 12:26 PM   #7
RudysWorld's Avatar
My problem with the same symptom was bad battery. As earlier stated replace both or the new one will be damaged and you will end up replacing 3 instead of two. IMHO. Yes this I the voice of experience talking.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 09-03-2015, 12:42 PM   #8
camaraderie's Avatar
X2 on Turbs. Sounds like a short in the first batt. Compare voltages when you have them both out of the coach...to rule out a converter issue,..hook up the good battery and plug in. Voltage should be between 13.1 and 14.5. Anything else means either you don't have a good battery #2 either....or a converter issue
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 09-03-2015, 02:27 PM   #9
lckeehne's Avatar
Cypress loser great info thx
lckeehne is offline   Reply With Quote
Old 09-05-2015, 11:42 AM   #10
relaced both of them hope it clear up the problem. Converter only putting out 13.5 volts
Old 09-05-2015, 12:25 PM   #11
Converter @ 13.5 is fine since the batts should already be pretty well charged. When the batts are depleted to 50% or so ...you should see the charger put out over 14V but not more than 14.5.
It should always put our 13V + no matter what the state of charge of the battery.
Sounds like you had a bad cell or two...good luck with they new ones.
________
Cam
battery, charging, power
