Old 09-09-2013, 02:38 PM   #1
ronald.saumure's Avatar
Battey isolator
Where is the battery isolator on a 2010 Sunseeker 2300?
Ottawa Ontario Canada
2010 Forest River Sunseeker 2300 Chevy
Alaska Trip Photos at http://tinyurl.com/ockgenb
ronald.saumure is offline   Reply With Quote
Old 09-09-2013, 06:02 PM   #2
The battery disconnect switch is located just to the left of the steps as you enter the coach, at floor level.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 09-09-2013, 06:10 PM   #3
I am looking for the isolator that the alernator uses to select what battery it will charge.
Old 09-09-2013, 06:22 PM   #4
MotocrossCamper's Avatar
I didn't know it decided. When my engine is running both the house batteries and the chassis battery show a charge.
MotocrossCamper is offline   Reply With Quote
Old 09-09-2013, 07:44 PM   #5
VinceU's Avatar
Most are under the steps near the coach battery, box with screwed cover.
Old 09-10-2013, 05:02 AM   #6
The battery control center is on the side of the cabinet to the left of the bottom step as you enter. There is a cover that is removed with a thumb screw. Several key fuses are located there.
Old 09-11-2013, 05:21 AM   #7
On the Sunseeker and Forester, the "Bi-directional Relay Delay" doesn't decide which battery to charge. It decides when to energize the relay that connects the chassis 12 volt system to the coach 12 volt system. It will connect the two systems when:
1. The convertor brings the coach system voltage high enough (in effect, there is enough extra 12 volt power to run the coach, charge the coach batteries, and charge the chassis battery at the same time),
2. The chassis alternator brings the chassis voltage high enough (as above, but in reverse),
3. Or, the driver engages the emergency start switch. This engages the relay and connects the two systems so the coach batteries can be used to boost the chassis battery to start the engine.
You can hear the relay when it is energized if there isn't too much noise. It's located behind a small panel on the left side of the lower step.
If the BIRD senses that connecting the two systems lowers the voltage too much, it will cycle the relay on and off every few minutes to avoid running down the batteries in the coach or chassis.
