Old 05-08-2015, 06:29 PM   #1
Battey Maintainer
Thinking about putting a maintainer on chassis battery due to extended periods of non-use.
I found this maintainer that would charge the chassis and two coach batteries.
https://www.amazon.com/dp/B003JSO1X2..._Erutvb1Y82MVZ
I am wondering if I need to maintain the coach batteries. Shouldn't the 110v I have it plugged into in storage do this? I thought so, but it appears the batteries are draining and not being recharged.
I have a 2012 Sunseeker 2450S.
2015 Jeep Wrangler Toad
SilverSunseeker is offline   Reply With Quote
Old 05-08-2015, 08:25 PM   #2
Average Joe
MrJoe's Avatar
My 2014 keeps the coach and chassis batteries charged while on shore power.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 05-08-2015, 08:41 PM   #3
Herk7769's Avatar
If shore power is available just use an adapter from your camper's cord to your 110 outlet. Just be careful not to use more than 15 amps of AC at once.
There is a battery control center that may be preventing the maintainer from charging the starting and coach batteries simultaneously.
However if your unit is wired like this, you must close (turn on) the battery disconnect to tie the coach batteries to the camper's battery control center.
Here is a generic schematic of how one works.
Name:	ImageUploadedByForest River Forums1399131746.485742.jpg
ID:	76468   Click image for larger version
Name:	ImageUploadedByForest River Forums1399131624.856895.jpg
ID:	76469   Click image for larger version
Name:	ImageUploadedByForest River Forums1399137840.553903.jpg
HAM CALLSIGN - KC3FFW
Old 05-11-2015, 05:17 PM   #4
I have looked at the manual and it says shore power will charge the batteries when the batteries are disconnected. The manual shows two options for a battery disconnect. One is a regular rocker switch. Another is a red key in a black box. This is the kind I am most used to seeing. I looked all over and can't find either of these types of switches.
In researching online someone said the switch I have attached a picture of is a battery disconnect. Is this true? If so, what position, On or Off, does it need to be in so the shore power will charge the batteries. If this isn't the switch I need where do I find the battery disconnect.
Name:   ImageUploadedByForest River Forums1431382412.741235.jpg
Old 05-11-2015, 05:26 PM   #5
2012 Solera
Yes, that is your battery disconnect. Doesn't disconnect everything though - on our 2012 Solera "S" the slide out, the awning, the steps still work with the switch "off". Suspect other stuff also. Believe Forest River recently changed to connect the converter before the switch so batteries get charged while connected to shore power whether switch is "on" or "off", but on our 2012 the switch must be "on" to charge the batteries with the converter from shore power.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 05-17-2015, 05:14 PM   #6
Great. Thanks for the help.
Old 02-02-2016, 06:36 PM   #7
Still having problems with this. I have the switch in the On position and the batteries are not being charged. Any ideas?
Old 02-02-2016, 07:10 PM   #8
2012 Solera
Occasionally my 2012 has tripped the circuit breaker that supplies 120 volt AC to the converter. When the breaker is tripped, it does not charge the house batteries. The only other thing that is on that breaker (besides the converter) is the 120 volt outlet "above the driver's head" on the base of the cab over area. All the other 12 volt systems work fine (off the house batteries). Don't know why it occasionally trip when I connect to shore power - has done it since new and seems to work fine after resetting the breaker.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 02-02-2016, 07:12 PM   #9
Find the converter. I is usually somewhere very near where the shore power connector comes in. Sometimes it is under the bed. When you find it, put a voltmeter across the output and see if it is 13.4 or higher. Less than that and a fuse might be blown...or the whole converter might be blown. Check to see if the circuit breaker in the panel labelled "converter" is turned on.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-10-2016, 11:53 PM   #10
MNtraveler's Avatar
Also check the voltage at the battery terminals - both the wires and the terminals of the batteries themselves. Don't rule out something simple like a bad battery connection. It's amazing how often that can be the problem. If you are getting good voltage across the wires but not the same level on the battery terminals without touching the wires, then the juice isn't getting through.
Also check the water levels in the batteries.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
