Old 05-23-2015, 05:54 PM   #1
Bigfoot leveler lifting front wheels off the ground?
I had my new to me Sunseeker with the Bigfoot leveler out for the first time yesterday. It leveled just fine on one spot, but I moved because it was a terrible spot. I got a better spot but it sloped toward the front. After the leveler was done, I jumped out and saw the front wheels off the ground a little bit. Is that ok? This wasn't a very good campground so none of the spots were all that great.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 05-23-2015, 06:28 PM   #2
Ford Idaho's Avatar
I would carry some wood ramps/boards and run the front tire on them to keep the lift to a minimum.
I would also carry something like this in case that last step is a doozy.
Platform Steps :: Stromberg Carlson
Old 05-23-2015, 08:36 PM   #3
Average Joe
MrJoe's Avatar
Mine does that sometimes. I don't like it because it moves more sticking up in the air. I have a couple 3" ramps I use just to keep a little weight on the wheels. Feels more stable that way.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 05-24-2015, 08:48 AM   #4
trdutch's Avatar
Happened to me once and I didn't feel compfy about it
I bought a bag of the orange stacking pads (Legos)
We talked about this on a thread a while back and the consensus was go to manual and do the best you can to level with tires at least touching the ground
I don't doubt the Bigfoot can handle the load but if the park fails in the tranny (my backs were off the ground)
It could be dangerous
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 05-24-2015, 09:47 AM   #5
Boso's Avatar
Don't lift the back off the ground front is fine won't hurt anything
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 05-24-2015, 12:10 PM   #6
Did you check the level inside the camper to make sure it is truly level. Sometimes the leveling systems get out of calibration and causes the jacks to respond incorrectly.
kswing60 is offline   Reply With Quote
Old 05-24-2015, 01:09 PM   #7
Is your control panel for the jacks silver and green?
[QUOTE=gmacklem;872136]I had my new to me Sunseeker with the Bigfoot leveler out for the first time yesterday. It leveled just fine on one spot, but I moved because it was a terrible spot. I got a better spot but it sloped toward the front. After the leveler was done, I jumped out and saw the front wheels off the ground a little bit. Is that ok? This wasn't a very good campground so none of the spots were all that great.[/QUOTE
Is your control panel for your jacks silver and green? I had issues with my new Sunseeker as well. They call them auto leveling jacks but they are not, if you have this control panel. I push start and they all come down the same distance. I must manually level the RV after that. I called Bigfoot and they said they are putting these in now because they were having problems with the self leveling ones not leveling properly.
Hepzeth is offline   Reply With Quote
Old 05-24-2015, 01:45 PM   #8
Witch Doctor's Avatar
That's crazy, Big foot is supposed to be a self leveling system as they advertize. If you wheels come off the ground block them in the up position then hit relevel. should take the pressure off the rams.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-24-2015, 01:54 PM   #9
Same issue with my Sunseeker if it's on really unlevel ground, I keep two sets of plastic stackable leveling blocks on hand. I also use a bulls eye level, place it in the freezer and check level, then take the level out. Have fun.
edcronin01 is offline   Reply With Quote
Old 05-24-2015, 02:04 PM   #10
rugersdad's Avatar
I have camped in spots where the left side tires were four or five inches off the ground, the camper is not as stable but i dont think it is anything to worry about. i do put blocks under the feet so the rams dont have to extend as far when i am in a spot that is not very level. Enjoy your autolevel.
rugersdad is offline   Reply With Quote
wheel
