Old 02-09-2015, 07:57 PM   #1
RV Wannabe
Bigfoot levelers - how low do the feet hang
Debating ordering the levelers on a 2300 Sunseeker on 4500 Chevy chassis. How much cargo carrying capacity will I lose do to the weight of the system?
szn8tt is offline   Reply With Quote
Old 02-09-2015, 08:01 PM   #2
RV Wannabe
Debating ordering the levelers on a Sunseeker 2300 on a Chevy 4500 chassis. In the stowed, up position, how far above the ground are the feet?
I have measured the lowest point of the chassis at about 6.5". It is the bottom of the axle "pig."
EDIT by site team: merged two similar threads into one
Old 02-09-2015, 11:08 PM   #3
GM
bclemens's Avatar
Height is fine to worry about...carrying capacity? No way. We normally put the 2300 on an E350 (only rated at 12,500lbs). BUT we only buy one Chevy...the 4500 which is rated at 14,200 lbs. You'll have about 4,000lbs of carrying capacity on that unit. That's as much as some diesel pushers.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 02-10-2015, 08:49 AM   #4
RV Wannabe
I'm with you there Brian. I love, love the OCCC of the 2300 on a Chevy 4500 Chassis.
I am always amazed checking class A's out at the RV show and looking at the yellow sticker to find ridiculously low cargo carrying capacity. Like, as soon as 2 people and a dog are on board, you are overweight.
So, sounds like Bigfoot weighs ~ 200 #.
What is the ground clearance of the feet when stowed?
Old 02-10-2015, 10:45 AM   #5
Hoglou's Avatar
How high..
If you don't have an answer by the time I get off work at 5 est I will measure the 2300 chevy 4500 big foot(s). They are low(er) compared to the rest of the coach but after two years I will say that I would really miss them if they were not there. That and things like the fiberglass roof, ducted heat pump, and the two way hot water were the reasons I keep coming back to Sunseeker during the shopping phase. I will also measure the rear axle pumpkin.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 02-10-2015, 12:55 PM   #6
RV Wannabe
That would be great, thank you so much.
Old 02-10-2015, 04:39 PM   #7
Hoglou's Avatar
Tale of the tape
To put into context the bottom of the coach side door to the ground is 10".
The bottom of the front bigfoot to the ground is 6.5".
The oil pan is about 8" from the ground.
The bottom of the rear bigfoot to the ground is 8.25".
The bottom of the pumpkin (rear axle) to the ground is 6.75".
The rear bigfoot is 5' behind the pumpkin.
So the summation is that dragging the rear bigfoot is not a big concern as you have an inset of 1.5". But I do still cross driveways at an angle with this.
I would love to hear from anyone who has dragged, and if they did I would bet it was a lot longer than the 2300 (further beyond the 5').
I am more concerned about the clearance of the DW's Avalon.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 02-10-2015, 06:01 PM   #8
RV Wannabe
Hoglou,
great information, thank you so much!
Old 02-10-2015, 09:02 PM   #9
Boso's Avatar
My 3050 scraped the top of my lawn the first 2 times I drove off the grass onto the road I had 55psi in the airbags I inflated to 75psi and it has not happened again but I wouldn't be surprised if I did have it to happen in another situation I do try to hit slopes very slow and at a angle my rv is about 32'
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 02-10-2015, 10:57 PM   #10
I have a 2860ds and had the Bigfoot levelers added after my purchase and was also worried about clearance but after 12000 miles the only thing that ever drags is the rear hitch. Going up or down small inclines causes this but the hitch has 2 pieces that extend down that look like that is what they are for is to protect the underside. Just go slow and know it is ok. Bigfoot is the best never had to do anything but push 1 button and level
Pacostaco is offline   Reply With Quote
