Old 08-31-2013, 12:41 PM   #1
black residue
I noticed this summer that there is black residue behind both tires I need to wash off. Is this from the tires or the brakes? Is this normal?
Sun.ranger is offline   Reply With Quote
Old 08-31-2013, 02:12 PM   #2
Perfectly normal but inspect your inner and outer tires for abnormal wear. You should see the diesel soot residue after driving from Maine to New Mexico - it's crazy from the big rigs.
mwebber78 is offline   Reply With Quote
Old 08-31-2013, 04:28 PM   #3
Be sure and check for axle seals and brake fluid etc.
Geaux is offline   Reply With Quote
Old 08-31-2013, 06:05 PM   #4
Easy to check for brake fluid, but how do you check for axle seals? I assume since it is on both sides it was normal brake wear or tire wear.
black
