Old 09-13-2016, 05:33 PM   #11
I was told that if you were to do what you did that the water would come up through your toilet and flood your bathroom floor in your camper.
flagstaffman is online now   Reply With Quote
Old 09-13-2016, 05:53 PM   #12
Was the water that spilled out black water or fresh water?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 09-13-2016, 06:32 PM   #13
LTRVing's Avatar
Fresh water, 2nd rinse. No smell at all, lucky, bleach cleaned all we could see. I normally babysit the process, however, just as I started I got an important phone call and got distracted for a few minutes too long. As soon a you think you've got this RV thing figured out, wammo, live and learn. Fortunatly no small animals were harmed during this screw up. ;-)
The Millers, enjoying life, spending the kids inheritance.
LTRVing is offline   Reply With Quote
Old 09-13-2016, 06:40 PM   #14
BandJCarm's Avatar
Rule 1: There are no important phone calls.
Rule 2: Blank Tank work requires direct oversight. It's like a 3 year old boy. Never turn your back.
Rule 3: Water is our blessing, and our enemy. Corralling it is one tough task!!
Rule 4: Gravity always wins in a battle including water.
Rule 5: Never mix hoses.
Rule 6: ....... Not sure there is a rule 6..........
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 09-13-2016, 06:58 PM   #15
mikkeeh's Avatar
Good thing this is a theoretical problem and didnt really happen!
mikkeeh is online now   Reply With Quote
Old 09-13-2016, 07:33 PM   #16
DouglasReid's Avatar
When Im flushong the black water tank I NEVER walk away from the camper. My wife monitors the level gauges and when it gets to 3/4 I drain it, probably do this twice each time we are leaving the campground.
There are too many horror stories of tanks bursting, falling, etc. to get in that big of a hurry!
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 09-13-2016, 07:58 PM   #17
Citrus County, Fl.
GL1800Rider's Avatar
I am always right at the connection or the faucet when I flush. Last time we were out the Pex connection where the hose hooks up broke on the barb after about a minute. Fortunately we had roughly a half gallon of fresh water to clean up. And for those who are wondering, I had my regulator and gauge on it and it was set at 40 psi.
2016 Forester 3011DS
2015 Toyota Corrola S toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 09-13-2016, 08:12 PM   #18
45 Minutes?
BamaBob;
Do you run it 45 minutes after EVERY BT flush or only when you are done camping and going to store it. That's a lot of water........I am fairly clear after a few minutes.......
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-13-2016, 08:14 PM   #19
Farkasb's Avatar
If your hose was hooked up to the black flush hookup there's a chance a hose or plastic fitting cracked. Happened to me, had a lot of water leaking down. Since it was fresh water it confused me till I found the problem.
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 09-13-2016, 09:10 PM   #20
Bilcin's Avatar
Absolutely correct. I had this happen. I was back flushing the black tank and got side tracked. Well, several minutes later I am outside the trailer and water is coming out of the slide seal. I rush around the trailer, shut the water off and go inside the trailer and water all over the bathroom floor and leaked into the living room slide and leaked out. I opened up the toilet lid expecting to see a toilet bowl full of yucky water. No water. The water was forced up and out of the seal between the toilet and the flange, and that broke the seal and had to be replaced. Bleach, bleach and more bleach for the floor. I now have a timer with alarm so I don't do this again.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
black, black tank, black tank flush, tank
